Inquiry for Cat 1000 series Switch
bilalmekati
Hi All,
Please, i have a SMB network installation for a small enterprise of 15-20 users, and i am planning to use Catalyst 1000 Series Switch and Cisco 900 Series Integrated Services Router.
Please is this a good devices? if not suggest for me others.
2 Accepted Solutions
@bilalmekati hello, those selected models are good. also you can check cisco CBS series for switches.
Good luck
KB
balaji.bandi
Small Business Switch are suggested for low cost and features.
make sure you check the end fo life notes before you buying any model
Other hand check Meraki switches it got nice dashboard free managing any where from world.
BB
Good luck
KB
bilalmekati
Thanks mate, i really appreciate your comment.
balaji.bandi
BB
OK, Thanks bro
