09-11-2023 10:06 AM
I have a Cisco SF 300-24pp switch. All the switches are connected in sequence, with the last one connected to the ISP modem. I want to configure the switch, but my console cable is not functioning due to it having a male console end and a female RJ45 end. I tried accessing the switch using the default IP address, 192.168.1.254, in a web browser, but it appears that the IP address has been changed. How can I determine the new IP address of the switch?
09-11-2023 12:10 PM
If the switch out of the box that should work, until any one configured already.
Try to reset to factory and try same option using Quick start guide :
https://www.youtube.com/watch?v=qjGKbPmbPho
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/quick_start/78-19252-01.pdf
09-12-2023 09:59 AM
Thank you.
09-11-2023 09:48 PM
Hello @hogrhonarfathalla,
Wireshark port of your Switch to have information about the new IP.
09-12-2023 09:59 AM
Thank you for your response, I'm login to my modem(ISP) and find the IP's
09-12-2023 03:14 PM
Sure that router have arp of the switch - good one
09-11-2023 11:57 PM
>...How can I determine the new IP address of the switch?
- From a neighbor connected switch issue the command : show cdp neighbors detail
M.
09-12-2023 09:59 AM
Thank you
