Looking OID to monitor on old 2960 Switch
christianpho
I'm using old C2960G-24TC-L running 12.2.55(SE12) for non-critical task. I hope the OID for this exact model would the same for all 2960 in the same generation.
But I will also have to find OIDs for 3750 & 3750v2 running also 12.2.55(SE12)
But to be more proactive then reactive, I would like to be able to monitor the following through SNMP in pulling method the following:
CPU usage, I think this one : "1.3.6.1.4.1.9.2.1.58" which return % usage in the last 5 minutes can someone confirm ?
Memory usage :
Fan status :
Temperature of the chassis
Thank you
I'm not sure if this command is available on 2960 but you can try to execute 'show snmp mib'.
Regards.
