Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3136 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4685 Views
  • 1 replies
  • 16 Helpful votes
Resolved! Problem with DHCP
Hello,I created 4 VLANS in my switych cisco SF300-48PPthe switch is connected to a 192.168.1.1 ADSL routerVLAN 1 address 192.168.1.6 DHCP 192.168.1.7-192.168.1.63 / MASK 255.255.225.192VLAN 2 address 192.168.1.65 DHCP 192.168.1.66-192.168.1.128 / MAS...
mmalaoui by Level 1
  • 6894 Views
  • 35 replies
In the network with SG300 switches I have a new SG350 switch.How to configure qinq on it? How should the Customer port be set to SG350? How to trunk between SG300 and SG350? Which Ethertype Tagging should be set?   On SG300 qinq works without problem...
Nolaan by Level 1
  • 3727 Views
  • 4 replies
hi,- what are the encryption algorithm supported on Cisco SG switches series for Both SSH and HTTPS?- how can i enable strong encryption algorithms on Cisco SG switches for both SSL and SSH?- is there a way to enable use of CTR, GCM ciphers on Cisco ...
I have a Cisco 112-24 and trying to verify the meaning of the LED lights since this is an unmanaged device and I can't get any other details.   Per the online docs, I see the LED indicators are:  System/PWR, link/activity, 100M,*PoE, *mMax PoE, cable...
tnwest by Level 1
  • 3126 Views
  • 1 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
