01-03-2012 02:31 PM
I have spent too much time on this now and need help. I am trying to configure a voice VLAN on an SG300-28p switch. I need to instruct a Cisco 7965 phone connected to a port on SG300-28p to use VLAN 100, and a workstation connected to the Cisco 7965 phone to use be placed on VLAN 101 by SG300-28p. In regular Cisco IOS switches, this task is configured as follows:
interface gi25
switchport mode access
switchport access vlan 101
switchport voice vlan 100
Trying to achieve this scenario with a Cisco SG300 switch is turning into a nightmare. You have to deal with a Dynamic Voice VLAN set to the Auto Voice VLAN mode. Then, you have to have a trigger configured and Auto Smartport enabled. I have tried to do this in CLI to no avail. The Cisco 7965 receives an IP from the access VLAN on interface Gi15, which is VLAN 101. I need it to receive an IP from VLAN 100.
The current configuration under interface Gi15 is as follows:
interface gigabitethernet15
storm-control broadcast enable
storm-control broadcast level kbps 10
storm-control include-multicast
port security discard trap 60
port security max 10
port security mode max-addresses
spanning-tree portfast
lldp med disable
!next command is internal
macro auto smartport dynamic_type unknown $native_vlan 101 $voice_vlan 100
Now, I have no idea how the macro auto smartport dynamic_type unknown $native_vlan 101 $voice_vlan 100 command got in the config, and I don't know how to remove it.
When I try to enter the macro auto smartport type ip_phone_desktop command under interface Gi15, I get the following error message:
Macro parameter $voice_vlan is not user configurable
It appears as though the standard auto smartport macro ip_phone_desktop cannot apply the $voice_vlan parameter with the value 100. As a matter of fact, I am not explicitly using this parameter at all in the macro auto smartport type ip_phone_desktop command; however, the SG300 switch knows that the its voice VLAN is VLAN 100, and as it is trying to use this VLAN ID as the value of the $voice_vlan parameter, the macro fails.
I tried to statically configure the voice VLAN on the SG300 switch by using the voice vlan id 100 command, but I could not get the ip_phone_desktop macro to configure inerface Gi15 properly. Then, I removed the voice vlan id 100 command and got SG300 to learn its voice VLAN ID from UC560 connected to SG300 via a trunk port based on the following UC560's trunk port (connected to SG300) configuration:
switchport trunk native vlan 101
switchport mode trunk
macro description cisco-switch
It is the switchport voice vlan 100 command that advertises to SG300 via CDP that VLAN 100 is a voice VLAN. When I issue the show voice vlan local command on the SG300, I get the following output:
VLAN-ID VPT DSCP Source MAC Address Interface
1 5 46 default ---- ---
*100 CDP e0:5f:b9:xx:yy:zz gi28
So, it is clear that the SG300 is receiving information from UC560 via CDP into port Gi28 that VLAN 100 is the voice VLAN. Nevertheless, I still cannot apply the ip_phone_desktop macro to SG300's interface Gi15.
By the way, I have tried to configure voice vlan state auto-triggered as well as voice vlan state auto-enabled global configuration mode commands. Neither setting changes anything vis-a-vis voice VLAN advertised to Cisco 7965 in that Cisco 7965 continues to use VLAN101 (access VLAN assigned to interface Gi15).
Solved! Go to Solution.
01-03-2012 03:08 PM
Hello telecastle,
The Macro's just get in the way most of the time. From a default state on the switch a user will set the voice vlan id with the commands
(config)#voice vlan id 100
** this will create vlan 100
voice vlan ? ** you can use to change your default dscp and cos settings a long with any other settings.
(config)#voice vlan state auto-enabled
(config)#interface range fa1-24
(config-if-range)#switchport trunk native vlan 101
(config-if-range)#switchport trunk allowed vlan add 100
** this will set the native vlan on the trunk port to 101 for data and the tagged vlan will be 101 for voice.
CDP is automatically enabled and should learn the capabilities of the phone and join the phone to vlan 101 on that port.
CDP from the UC should automatically populate the SG switch. You may need to upgrade the switch to the latest firmware though. Also make sure the DHCP server for the voice if the UC needs to be setup accordingly.
Let me know if that helps.
Cisco Small Business Support Center
Randy Manthey
CCNA, CCNA - Security
