05-23-2013 11:40 AM
I am going to be putting an SG200-08 (8 port switch) inside a 2U rackmount chassis.
To enhance cooling I thought I would remove the outer case.
Are there, or would there be any issues with using the switch with the cover removed?
Glen
Solved! Go to Solution.
05-23-2013 12:23 PM
Hi Glen, the first issue would be, the warranty is void and you're not entitled to any support. The second issue would be static electricity and environmental concerns. The third issue would likely be your property insurance.
It is highly against recommendation to alter or modify these units.
-Tom
Please mark answered for helpful posts
05-23-2013 12:23 PM
-Tom
05-23-2013 12:31 PM
Thank you.
