12-07-2018 09:43 AM
I created 4 VLANS in my switych cisco SF300-48PP
the switch is connected to a 192.168.1.1 ADSL router
VLAN 1 address 192.168.1.6 DHCP 192.168.1.7-192.168.1.63 / MASK 255.255.225.192
VLAN 2 address 192.168.1.65 DHCP 192.168.1.66-192.168.1.128 / MASK 255.255.225.192
VLAN 3 address 192.168.1.130 DHCP 192.168.1.7-192.168.1.190 / MASK 255.255.225.192
VLAN 1 address 192.168.1.192 DHCP 192.168.1.193-192.168.1.250 / MASK 255.255.225.192
My problem what I have the internet only in the VLAN1 not in the others
Cordially
Solved! Go to Solution.
12-14-2018 05:11 AM
Problem solved, it was necessary to put back the mask of the Modem ADSL with 255.255.255.0 thanks for everyone cordially
12-07-2018 09:51 AM
is this typo or why there 2 VLAN 1 available here ?
By default VLAN 1 is Nat , you need to configure other VLAN to NAT
below guide help you:
12-07-2018 12:25 PM
vlan4 not vlan1
12-08-2018 02:18 AM
ok, then we would be more interested to see your NAT config along with routing.
12-08-2018 02:21 AM - edited 12-08-2018 05:37 AM
I saw the document but I can not find it or configure NAT
on the other hand I configure my switch by program Managed SWITCH
cordially
12-08-2018 09:12 AM
Can you post the configuration to have look.
12-08-2018 09:21 AM
12-09-2018 05:03 AM
Please make sure your ADSL Router LAN Pool IP subnet mask is similar to the VLAN 1 (VLAN 10 as per the screenshot) IP Subnet, after that you need to apply the static routes (reverse route) on the ADSL Router for the remaining VLANs configured on the Switch towards the IP 192.168.1.6 (assuming that 192.168.1.6 IP is directly communicating with your ADSL Router (192.168.1.1). Also make sure you have configured the DNS settings on the DHCP pools (you may try 8.8.8.8).
In case ADSL Router IP configured as 192.168.1.1 /24 then it will better if you can use the IP subnet like 192.168.2.0 /24, 192.168.3.0 /24 for the respective VLANs on the SF300 Switch and accordingly apply the reverse route on your ADSL Router to allow the Internet Access for the other VLANs on the Switch.
On the attached screenshots VLAN are showing as VLAN 10,20,30 & 40. FE1 port is showing ‘Tagged’ and remaining ports are ‘Untagged’. It will be better if you can share the ‘Port VLAN Membership’ scrennshot.
In case your ADSL Router supports 802.1Q Trunking then you can use the ‘Tagged’ option otherwise you may keep the port settings as ‘Untagged’.
12-09-2018 07:44 AM
12-09-2018 07:46 AM
12-10-2018 06:25 AM - edited 12-10-2018 06:27 AM
As i understood from this IPs,
You need to have IP address for each vlan in switch. That IP will be the gateway for those VLANs.
Then add default route to adsl router IP address using static routes.
At ADSL router you should add static routes for each VLAN network, Which are pointed to switch VLAN 1 IP
12-10-2018 10:37 AM - edited 12-10-2018 10:38 AM
12-10-2018 12:37 PM
This example : you can do same for all VLAN and test and advice.
Destination address : 192.168.1.65
subnet sk MASK 255.255.225.192
gateway : 192.168.1.6 ( as per your information the router IP)
12-10-2018 02:45 PM
12-10-2018 06:43 PM
