restrict vlan for mac address
lima.pedro
Hello sirs, I bought a sf300 48 and made 4 vlans.
How can I restrict the mac address of device can be connect each vlan ? I just want allow the macs for vlan, dont need join the pc to a vlan.
Thanks so much!
Pedro here is a document for port security.
https://supportforums.cisco.com/docs/DOC-27720
https://supportforums.cisco.com/docs/DOC-27753
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
8 Replies 8
Tom Watts
Hi Pedro, the Sx300 series supports vlan groups based on MAC address.
http://www.cisco.com/en/US/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/78-19308-01.pdf
Page 194 of the admin guide on down through 197 should be helpful. Remember vlan group is for only layer 2 mode of the switch.
-Tom
Thanks mr Tom for the fast reply, I dont know but I think put in layer 7. I dont remeber. Could I make this changes on layer 7 ?
What is your goal exactly?
Do you want ports to assign a VLAN id based on a mac address?
Do you want to restrict access from 1 vlan to another by mac address?
-Tom
Sorry for my bad eng, but I will try explain to you.
I have 5 pcs on one vlan, this vlan is a security vlan for develop. I just want this computer can connect on this vlan. In the switch sf300 the 5 ports of sw is marked for this vlan. I want keep safe this ports for just the 5 mac address can connect on this.
Understand?
This is the translate of googole :
I have a vlan that would have only 5 computers can connect them. Vlan This was made ​​from a 5-point networks directly connected to the switch. I would like to prevent just these 5 computers can connect the network cable that vlan through the mac.
thanks!!!!
If you want to restrict the MAC you can implement port-sercurity on the ports.  If someone else connects their PC to this cable it will not allow them access.
Perfect, but can I put a list of mac or just one mac per port?
And what settings I configure? I sow ACL, ADE ipv4... so many :S
Very thanks mr Tim!
-Tom
jonatrod
Level 7
Level 7
Hi Pedro
You post your question in a wrong forum, post in "Small business Switches". You can move your post using the actions panel on the right.
Greetings
Johnnatan Rodríguez Miranda
“Please rate useful posts so other users can benefit from it” Greetings, Johnnatan Rodriguez Miranda. Cisco Network Support Engineer.
