SG 300-28p vlan configuration
parrafran
I have been trying to setup vlans on a SG300-28p but they are not working.
This is my setup:
I want Switch1 to have ports 1-10 to access the DMZ, and 11-24 the LAN.
Then i wan to add switch2-4 to extend the access to LAN.
Is this possible?
i tested with cisco 2960 switches by just telling what ports whould have access to
DMZ and LAN but the small business switches are different..
I really appreciate the help!
Tom Watts
Hi Francisco, assuming the 2960 worked and there was no configuration difference then the problem would be that you did not add the vlans to the trunk.  On a Catalyst you do not configure the vlans on a trunk since all vlans pass. On the SB switches you have to configure the vlans on the trunk otherwise only the native/default vlan works.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Tom Watts
-Tom
