Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2890 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4458 Views
  • 1 replies
  • 16 Helpful votes
Hello,I was wondering what fibre SFP module I use to stack SG500 switches at 5Gb.In the datasheet it says SFP-10G-SR can be used for 10Gb stacks with SG500X switches but doesnt say if it can or can't be used on the SG500.I am using mulitmode fibre an...
Hi,I need some help on vlan configuration.Below is my configuration so far.GE1     General     1UP, 100T, 101TGE26   General     1UP, 100U, 101UBut I could not get port GE1 on vlan 100 to ping to anything on GE26.It only works when i change it to 100...
kopiboi55 by Level 1
  • 871 Views
  • 1 replies
I am facing an issue while installing the the SGE2010P switch with UC560. There are two switches in the site one SF300 and SGE2010P. The SF300 is working fine. But the SGE2010P switch is making issue. I connected the UC560 to the SF300 directly and c...
I am trying to get an SF500 in to CCA for configuration. I can find the device in CCA, and it prompts for a username and password, but it doesn't accept the u/p combo. I confirmed that the combo works when telnetting to it.I have telnet, ssh, HTTP an...
J W by Level 1
  • 744 Views
  • 1 replies
Hai,i got my client got the problem regarding to the dhcp ip problem. It occurs once in a month every month. then back to normal.then got problem cannot get dhcp.the switch is cisco small business . Can i get idea what the problem from you all ?...th...
Resolved! sf 300
Dear's friend        I have struck in my some network configuration.  I have two sf300 switches and cisco 827 router.  Actually sf300 does not support dhcp server.  I took cisco 827 as dhcp server and i create 4 dhcp pools in it.How i can configure i...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
