SG200-26: dynamic VLAN - 802.1X
Nachtfalkeaw
Last week I got my SG200-26 (SLM2024T-EU). The Data Sheet says, that the switch works with dynamic VLAN assignment over 802.1X.
IEEE 802.1X
(Authenticator role)
802.1X: RADIUS authentication and accounting, MD5 hash
Supports time-based 802.1X
Dynamic VLAN assignment
The authentication on freeRADIUS works. I client could get access to the network after entering username and password but the client is not assigned to a VLAN. I used wireshark to sniff the authorisation process between the switch and the freeRADIUS server and the VLAN information were transmitted to the switch.
I would appreciate if some could give me some help how to configure the switch to work with dynamic VLAN assignment and freeRADIUS. If you need some more information, please let me know. I will add them here as far as possible.
Thank you very much!
Alexander
Edit
23 Replies 23
Alexander,
The Dynamic Vlan worked with the SG200-26?
I will buy this switch and I need this feature. At documentation I was with doubt too.
Thanks.
Gustavo
@Gustavo
The Data Sheet says, that the switch will work with dynamic VLAN assignment. This was the reason, why I bought 20 of these switches.
But nobody in this forum could tell me how to configure this. I suppose, that there is a firmware bug, becaus the freeRADIUS .pcap files are correct. I told somebody in another forum to check my freeRADIUS configuration and verified, that it is correct.
In the next days oder next week I will try the hotline but it stresses me, that I will have to explain everything again and then probably send al .pcap files again.
IF I get theses switches working with dynamic VLANs, I will post my configuration here in this thread. IF NOT, I will sent all switches back and use another supplier like HP.
I hope this will help ypu, Gustavo.
Alexander
Hi Alexander,
I can assure you that when you open a case with the SBSC, you can refer to this thread on the community so you don't have to explain everything again. The SBSC agent handling your case will retrieve all data from this thread and put it in the case notes.
Unfortunately I still did not have the time to replicate your issue and as I am going on PTO tomorrow I will not be able to work on your issue in the coming week, therefor, I strongly suggest you open a case with one of my German speaking colleagues here in the support center.
The help on this community is on a best effort basis, and cases logged within our system get priority above working on the community, so in order to have a faster result, please contact us and have a case logged, this is also necessary if your problem might turn out to be a bug or not working functionality in the switch.
Hope this helps,
Best regards,
Nico Muselle
Sr. Network Engineer - CCNA
Just for your information:
I called the germany support hotline and they opened case (617466575).
I gave them the link of this thread.
We don't see your running configuration having dynamic VLAN assignment enabled on the interfaces.  You have to enable "RADIUS VLAN Assignment" at the desired interface(s) from 802.1x > Port Authentication GUI page.  Hope this will resolve the problem.
If not we also need to see  the debugs from the FreeRadius.
Plamena Licheva
No, this di
didn't resolve the problem!
There is no Option "RADIUS VLAN Assignment" or I didn't find it.
I attached you three pictures of the GUI I can see.
Further I attached you the radius log running "radiusd -X"
Greetings  Mr. Wilke,
You are right sir,
There is no option to enable "Dynamic VLAN assignment " in the web gui of the switch. It's written in the Datasheet, but it's a mistake that has been reported and it will be fixed.
Please contact us for futher information -
Thank you
With best of my regards,
Plami
Hello Mrs. Licheva,
did you get my E-Mail from 28. April 2011 ?
I didn't get any feedback till now ?
Thank you very much.
Hello Mr. Wilke,
Yes, I received your email. I have escalated the case, that we have and I am
currently waiting for replay.
Thanks for the understanding.
Greetings,
