SG200-26 password reset
emonge4242
New in a company that have 2 SG200-26, The system administrator left without giving any password.
Is there a way to reset the password, I can't find something that applies on thos switches.
The best would be to reset the password without reseting the configuration as our company relies on the network...
Thanks for your help.
8 Replies 8
Davidwagman1
Level 7
Level 7
Hi Eric,
Do you have serial access to the physical switch? Reboot the switch. You will see a prompt during boot right after the cisco logo made out of #s that says "Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom."
Hit return, and you will get the following startup menu:
Startup Menu
Download Software
Erase Flash File
Password Recovery Procedure
Set Terminal Baud-Rate
Stack menu
Back
Enter your choice or press 'ESC' to exit:
You'll want Password Recovery Procedure and follow the prompts to reset the password without erasing your config file.
My SG's baud rate is set to 115200, but I don't know if thats the default.
Let me know how it goes.
Best,
David
Please rate helpful posts.
Hi David! It work's for Cisco Small Business 300 Series Smart Switches  ( SG300-20 ) too! Thank you!
P.S. baud rate 115200 is used by default
Hi Andrey,
Thanks for confirming the baud. Glad to hear it worked on your SG300-20.
Best,
David
Hello David!
I am new to Cisco equipment. Could you please tell me where is the console port on
SG200-26P? Do I need a special COM port cable to access console?
Kirill
Hi Kirill, this box does not have a console connection. If the password is lost, a factory reset must be performed holding reset for 30 seconds.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hi Tom!
Thank you for answer! But i am completely lost :). What is David talking about?
In fact in the manual of this switch I found exactly same procedure, like David describes, for boot password reset. The only question is that I do not understand how to to get to boot screen
Regards, Kirill
On a SX300 series that is true, not on a SX200 series.
Here is a document for the SX300 with most of the process for a SX300 model.
https://supportforums.cisco.com/docs/DOC-27000
You'll notice on step 4 to use option 3 instead if you want to recover a password.
If you're using a SX300 then you can do this, if you're using a SX200 you cannot.
-Tom
Ok Tom, it is clear now.
SG300-26 has console port, but SG200-26 does not.
Thank you for help!
Kirill
