SG200-26P error message
briangroper
Hi forum
Newbie here, so thanks for being gentle.
When I try to edit the Administrative PVID for port 25 from 4095 to 1, it gives error as "Port gi25: IP Interface is defined on Port.."
TIA's for clues for how to undefine the IP interface on port 25, so that this error can be cleared.
Tom Watts
Hi Brian, can you first try to make the port an access port then assign any vlan to it as untagged?
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hi Tom
Thanks for your reply.
I try to do this as follows ?
VLAN Management, Interface Settings, select 25, Edit,
Then change Interface VLAN Mode from General to Acess,
Administrative PVID now greys out.
When I click Apply, it gives error in red :
"Port gi25: Default Vlan Tagged prevents executing Access mode"
Should I be doing this another way ?
TIA's
Edit.
Using VLAN Management, Port to VLAN, try to make GE25 as "Untagged".  Gives error
"In order for an interface to become an untagged member of the default VLAN, its PVID must be set to the default VLAN's PVID."
Does this give any more clues ?
Might be correct answer
Administration, Management Interface, IPv6 Interface, Select and delete GE25.  Save configuration.
spookfish1
Say for example your config looks like this
interface gigabitethernet50
 shutdown
 description "problem interface"
 ip source-guard
 switchport trunk allowed vlan add 60
 switchport default-vlan tagged
then the following commands will fix it
FINDSDW001(config-if)#no switchport trunk native vlan
FINDSDW001(config-if)#no switchport default-vlan tagged
FINDSDW001(config-if)#exit
FINDSDW001#conf t
FINDSDW001(config)#interface GigabitEthernet 50
FINDSDW001(config-if)#switchport mode access
! done
