02-07-2019 04:51 PM - edited 02-07-2019 05:28 PM
I am trying to assign a public IP address to my PDU which acquires an IP address automatically via DHCP so i can manage remotely. I have tried this with the switch mode in Layer 2 and didn't get it to work so now I'm trying in Layer 3. I have connected the PDU ethernet to the cg300 switch port 2. I created a vlan named vlan 50 and assigned a public IP address we'll call x.x.x.x netmask y.y.y.y
I have given switchport access to port gi2 and associated vlan 50 with gi2. I am thinking I should now be able to ping the switch from my office but the public IP is not pingable. I should also mention the switch is connected at the datacenter where they have the network setup for static routing so setting up DHCP within my own network is at my discretion. What am I missing? Thank you for any help and suggestions.
switchd0cfa7#show run
config-file-header
switchd0cfa7
v1.4.9.4 / R800_NIK_1_4_205_011
CLI v1.0
set system mode router
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 50
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
bonjour interface range vlan 1
hostname switchd0cfa7
username cisco password encrypted 1f4x4f6ccae8e9bx653d4e85dxb78x77816f9x1edb privilege 15
interface vlan 50
name PDU
ip address x.x.x.x y.y.y.y
interface gigabitethernet2
ip address dhcp
switchport mode general
switchport general allowed vlan add 50 tagged
switchport protected-port
exit
switchd0cfa7#show vlan
Created by: D-Default, S-Static, G-GVRP, R-Radius Assigned VLAN, V-Voice VLAN
Vlan Name Tagged Ports UnTagged Ports Created by
1 1 gi1,gi3-52,Po1-8 V
50 PDU gi2 S
02-07-2019 08:25 PM
I can also see the MAC Address of the device (PDU) so I know it's connected. I am not sure how to find the IP address it is using.
#show mac-address-table
Vlan Mac Address Port Type
1 00:06:67:41:15:c1 gi2 dynamic
1 00:23:8b:77:8f:25 gi1 dynamic
1 00:d0:01:77:48:00 gi48 dynamic
1 cc:8e:71:d0:cf:a7 0 self
02-09-2019 12:35 AM
02-09-2019 11:21 AM - edited 02-09-2019 11:21 AM
Hello Jaderson,
Thanks for response. So if I change the default gateway of the vlan or the sg300-52 switch from LAN to WAN (to a public IP)? Is that what you are saying? The sg300 can be set in Layer 3 mode. I have around 30 IP addresses from the datacenter in 4 groups each have different subnets and gateways. Everything appears to work fine through vlan1 just connecting the servers to a port and configuring NIC for IP address.
I had also wanted to change the switch default-gateway to a public IP so I could access the switch web interface remotely but had trouble configuring that also. I am able to connect through CLI so I can change anything.
I am just trying to separate the PDU device from the main VLAN 1 and have it pull an IP address that is assigned to the VLAN. Should the VLAN 50 IP address be the default gateway of the IP address I was trying to use? Then create an access list allowing the IP address I am trying to use?
02-09-2019 02:34 PM
