sg300-52P consistant system light flashing
Johnny_556
Greetings,
For some reason my switch keeps flashing the system light constantly and even if I try to hold the reset button for 30 secs to clear all configuration and start from scratch it does not work. I can get access to the console but once I clear the password and reboot it goes to the old settings and i cant do anything. I have documented everything from the CLI to notepad if anyone need to take a look at it.
balaji.bandi
You need to use GUI and look at the Quick start guide :
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/quick_start/78-19252-01.pdf
BB
Johnny_556
Thanks for the suggestion BB, I have already took a look at it without any solution. Today I tried to get into the console since by GUI it wouldn't let me and this is what came up.
Boot1 Checksum Test...............................PASS
Boot2 Checksum Test...............................PASS
Flash Image Validation Test.......................PASS
BOOT Software Version 1.3.5.06 Built 21-Jul-2013 15:12:10
Networking device with Marvell ARM CPU core. 128 MByte SDRAM.
I-Cache 16 KB. D-Cache 16 KB. L2 Cache 256 KB. Cache Enabled.
MAC Address : 1c:de:a7:74:22:17.
Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom.
Startup Menu
[1] Download Software
[2] Erase Flash File
[3] Password Recovery Procedure
[4] Set Terminal Baud-Rate
[5] Back
Enter your choice or press 'ESC' to exit:
Exit from boot menu. Continue with flow.
Both images are not valid ...
Please download a new image.
Downloading code using XMODEM.
Operation timeout.
Download failed
Perform WARM BOOT ...
Looks like something went wrong here...
Operation timeout.
Download failed
if this keeps doing,  Time for raising a TAC case RMA time.
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
BB
