Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3053 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4628 Views
  • 1 replies
  • 16 Helpful votes
I have an issue with switch SG220-26P180 watt, I am using the switch to operate 3 IP  cameras 7watt POE, but the cameras are not stable Is this because of POE for switch for each port 7.5 watt (180/24) and if it is , is there POE ports configuration ...
I have an SG350-28P I am trying to configure as follows:VLAN 1 - DefaultVLAN 100 - Customersand use the capability of the unit to provide DHCP for the VLAN 100.I've been able to configure the DHCP, but how do I associate the DHCP pool to the VLAN 100...
pd4294 by Level 1
  • 1947 Views
  • 3 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
