SG300 Boot fail need help plz
Ethan and Mia
Beginner
Beginner
Networking device with Marvell ARM CPU core. 128 MByte SDRAM.
I-Cache 16 KB. D-Cache 16 KB. L2 Cache 256 KB. Cache Enabled.
MAC Address : b0:00:b4:0d:53:87.
Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom.
Both images are not valid ...
Please download a new image.
Downloading code using XMODEM.
Download failed
Perform WARM BOOT ...
Boot1 Checksum Test...............................PASS
Boot2 Checksum Test...............................PASS
Flash Image Validation Test.......................PASS
BOOT Software Version 1.3.5.06 Built 21-Jul-2013 15:12:10
5 Replies 5
is that keep rebooting? what is the issue, have you tried a factory reset?
BB
@Ethan and Mia seems like image corrupted. try resetting first. if that is not worked, try to upload image to device using xmodem when xmodem OS requested and try to boot.
Good luck
KB
Thank for replying
Do u have guide how to do it please
seogirl
Beginner
Beginner
Here are a few steps you can try to troubleshoot the issue:
  1. Check the power supply: Ensure that the switch is receiving power and that the power supply is functioning properly.
  2. Check the cables: Make sure that all cables are securely connected and not damaged.
  3. Check the boot configuration: Verify that the boot configuration is correct and that the switch is attempting to boot from the correct image.
  4. Attempt a factory reset: If all else fails, attempt a factory reset by following the instructions provided in the user manual.
  5. Contact technical support: If the issue persists, it may be necessary to contact the manufacturer's technical support team for further assistance.
I hope these steps help you resolve the boot failure issue with your SG300 switch. Good luck!
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
