SG300 DHCP on VLAN not working
viningele
Level 3
Level 3
I have 3 AP-571, 1 RV320 and 1 SG300-28MP.
My APs have two VLANs 1 & 50 with 50 being tagged on both ports although only one connection.
My RV320 is has no DHCP servers but set to relay to my SG300 SVLI's.
My SG300 is my dhcp server and in L3 mode.  I know I would have been better off in L2 mode and us the RV320 as server doing the intervlan routing but is now is waht it is.  I have 4 vlans in total and each has an interface and a dhcp scope defined.  My switch ports to the APs are trunks with all VLANs included 1 untagged and the others tagged.
My wifi guest network has no password and that is on vlan 50 but I do not get an IP address from the server and it did work before I replaced to old APs with the 571's but I don't think the 571's are the problem.
I do have ACL's to prevent VLAN 50 from accessing the other VLAN.
What am I missing?  Why do I not get an IP?  If I change the guest wi-fi to vlan 1 it obviously works and I've read in other posts that others have had issue with receiving a dhcp IP on vlans.
config
config-file-header
SG300-28MP
v1.4.8.6 / R800_NIK_1_4_202_008
CLI v1.0
set system mode router
file SSD indicator plaintext
vlan database
vlan 25,50,100
exit
no eee enable
ip dhcp server
ip dhcp excluded-address 192.168.185.221 192.168.185.230
ip dhcp pool host FIOS-MODEM
address 192.168.185.122 255.255.255.0 client-identifier 01:00:7f:28:d9:bb:75
default-router 192.168.185.254
dns-server 8.8.8.8
exit
ip dhcp pool network AMX-POOL
address low 192.168.186.100 high 192.168.186.150 255.255.255.0
default-router 192.168.186.254
dns-server 8.8.8.8 8.8.4.4 192.168.185.1
exit
ip dhcp pool network CAM-POOL
address low 192.168.187.130 high 192.168.187.150 255.255.255.0
default-router 192.168.187.254
exit
ip dhcp pool network GUEST-POOL
address low 192.168.188.100 high 192.168.188.149 255.255.255.0
default-router 192.168.188.254
dns-server 8.8.8.8
exit
ip dhcp pool network VLAN-1-POOL
address low 192.168.185.50 high 192.168.185.149 255.255.255.0
dns-server 8.8.8.8
exit
no boot host auto-config
bonjour interface range vlan 1
ip access-list extended DENY-GUESTS-IN
deny ip 192.168.188.0 0.0.0.255 192.168.185.0 0.0.0.255 ace-priority 1
deny ip 192.168.188.0 0.0.0.255 192.168.186.0 0.0.0.255 ace-priority 2
deny ip 192.168.188.0 0.0.0.255 192.168.187.0 0.0.0.255 ace-priority 3
permit ip any any ace-priority 6
exit
ip access-list extended ALLOW-NON-GUESTS
deny ip 192.168.188.0 0.0.0.255 any ace-priority 2
permit ip any any ace-priority 3
exit
ip access-list extended ALLOW-ANY-ANY
permit ip any any ace-priority 1
exit
ip access-list extended Deny-Guests-LAN
deny ip 192.168.188.0 0.0.0.255 192.168.0.0 0.0.255.255 ace-priority 1
exit
hostname SG300-28MP
line console
exec-timeout 30
exit
line ssh
exec-timeout 30
exit
line telnet
exec-timeout 30
exit
passwords complexity min-length 3
no passwords complexity enable
passwords complexity min-classes 1
passwords aging 0
xxxxxxxxxxxxxxxxxxx
ip ssh server
snmp-server location "AV Room"
snmp-server contact VAV
ip http timeout-policy 1800
clock timezone " " -5
clock summer-time web recurring usa
clock source sntp
clock source browser
sntp unicast client enable
sntp unicast client poll
sntp server time-c.timefreq.bldrdoc.gov poll
ip name-server 8.8.8.8 8.8.4.4 192.168.185.1
ip telnet server
interface vlan 1
ip address 192.168.185.254 255.255.255.0
no ip address dhcp
service-acl input Deny-Guests-LAN default-action permit-any
interface vlan 25
name AMX
ip address 192.168.186.254 255.255.255.0
ip dhcp relay enable
interface vlan 50
name Guest-WiFi
ip address 192.168.188.254 255.255.255.0
interface vlan 100
name Cameras
ip address 192.168.187.254 255.255.255.0
interface gigabitethernet1
port security max 10
port security mode max-addresses
service-acl input ALLOW-ANY-ANY default-action permit-any
switchport mode access
power inline limit 0
power inline never
interface gigabitethernet2
power inline never
interface gigabitethernet3
power inline never
interface gigabitethernet4
power inline never
interface gigabitethernet5
power inline never
interface gigabitethernet6
power inline never
interface gigabitethernet7
power inline never
interface gigabitethernet8
description BSMNT-BED
switchport access vlan 50
power inline never
interface gigabitethernet9
description AIRPORT-EXPRESS
power inline never
interface gigabitethernet10
power inline never
interface gigabitethernet11
description SYN-DS-1
switchport access vlan 100
power inline never
interface gigabitethernet12
description SYN-DS-2
power inline never
interface gigabitethernet13
switchport access vlan 25
interface gigabitethernet14
interface gigabitethernet15
interface gigabitethernet16
interface gigabitethernet17
interface gigabitethernet18
description Back-Patio-Cam
interface gigabitethernet19
description Back-BBQ-Cam
interface gigabitethernet20
description Porch-Cam
interface gigabitethernet21
description Driveway-Cam
interface gigabitethernet22
description Playroom-AP-TRNK
port security max 256
spanning-tree link-type point-to-point
switchport trunk allowed vlan add 25,50,100
macro description ap
macro auto smartport type ap $native_vlan 1
interface gigabitethernet23
description Pantry-AP-TRNK
interface gigabitethernet24
description Center-BED-AP-TRNK
interface gigabitethernet25
description TO-RV320-TRNK
storm-control broadcast enable
storm-control broadcast level 10
macro description router
macro auto smartport type router $native_vlan 1
interface gigabitethernet26
description AMX-GRP-SW
macro description "switch "
interface gigabitethernet27
interface gigabitethernet28
exit
ip dhcp snooping vlan 25
ip dhcp snooping vlan 50
ip dhcp snooping vlan 100
ip default-gateway 192.168.185.1
ip ssh-client key rsa key-pair
mipopov
remove these commands:
from configuration. dhcp relay is used to relay (transit) the packets. You do not need this because the switch itself is a DHCP server.
Cheers,
Mike
mipopov
Cheers,
Mike
I updated it remotely but the client said it’s now working.
