11-21-2011 08:29 AM
the 300 series administation guide states on page 287:
The authentication methods can be:
* 802.1x
* MAC-based—The switch can be configured to use this mode to
authenticate and authorized devices that do not support 802.1x. The switch
emulates the supplicant role on behalf of the non 802.1x capable devices,
and uses the MAC address of the devices as the username and password
when communicating with the RADIUS servers. MAC addresses for
username and password must be entered in lower case and with no
delimiting characters (for example: aaccbb55ccff).
So this is just what we know as mac auth bypass in IOS terms.
However the implementation is not quite the same:
Here a mab request from a IOS device as seen by freeradius:
rad_recv: Access-Request packet from host 192.168.0.1 port 1645, id=35, length=160
User-Name = "001c25a2104c"
User-Password = "001c25a2104c"
Service-Type = Call-Check
Framed-MTU = 1500
Called-Station-Id = "8C-B6-4F-1A-C4-05"
Calling-Station-Id = "00-1C-25-A2-10-4C"
Message-Authenticator = 0x81a4802ccb11e5da3d1f0b78c1c04db1
NAS-Port-Type = Ethernet
NAS-Port = 50005
NAS-Port-Id = "GigabitEthernet0/5"
NAS-IP-Address = 192.168.0.1
And now the same request with a sg300-10 device (latest firmware):
rad_recv: Access-Request packet from host 192.168.0.2 port 49181, id=0, length=108
NAS-IP-Address = 192.168.0.2
NAS-Port = 56
EAP-Message = 0x0200001101303031633235613231303363
Message-Authenticator = 0x7e5e378a5324111080b1c0ff7d6a9add
192.168.0.1
The device does not send the User-Password = mac-address - why? It says so in the admin guide (see quote above)?
11-22-2011 11:57 AM
Dear Cisco,
I figured out on my own that the password is transmitted as md5 hash when doing the eap challenge/response stuff.
That makes no sense, as MAB is unsecure by design, so I just compare User-Name and Calling-Station-Id and send
Sending Access-Accept of id 0 to 192.168.0.2 port 49181
Tunnel-Type:0 = VLAN
Tunnel-Medium-Type:0 = IEEE-802
Tunnel-Private-Group-Id:0 = "9"
via freeradius, however the switch logs:
22-Nov-2011 20:42:16 %SEC-W-SUPPLICANTUNAUTHORIZED: MAC 00:1c:25:a2:10:4c was rejected on port gi7 because Radius accept message does not contain VLAN ID
What the heII?!
Note: it works perfectly well when processing normal 802.1x requests.
I can only imagine that the switch wants the answer in a nice eap envelope.
However, before I waste more time on this I want a clear statement from the cisco guys.
Bonus would be if you can give an example of how MAB is meant to work on sg300 devices
with freeradius. And I do not mean the easy way via users file ...
Thanks!
11-25-2011 02:17 PM
Hi jan
Here is my MAC based authentication configuration below for interface Gigabit 1, give it a try and see how it goes. I was waiting for someone else to answer your query for the following reason.
I am using a NSS324 NAS unit with Radius server add-on module for Radius authentication, which will not authenticate the incoming MAC based requests so I will always fail any mac based requests coming in, as you can see from my radius log that follows;
![]() | 2011-11-25 | 17:07:09 | 000e7f74bd48 | 192.168.10.22 | --- | RADIUS | --- | Auth Fail |
![]() | 2011-11-25 | 17:06:09 | 000e7f74bd48 | 192.168.10.22 | --- | RADIUS | --- | Auth Fail |
(My NAS supports PAP, EAP-TLS/PAP, and EAP-TTLS/PAP authentication schemes for system user accounts.)
However, the switch is configured to push the unauthorized MAC address client into vlan100.
So that's what I did to validate MAC based authentication was progressing by checking the;
As you can see from the screen captures below, the switch added Gi1 to vlan100 as a results of failed authetication attempt..That's whay I expected.
switch0fdcfd#show vlan
Vlan Name Ports Type Authorization
1 1 gi2-10,Po1-8 Default Required
100 100 gi1,gi10 permanent Guest
switch0fdcfd#sh system
System Description: 10-port Gigabit PoE Managed Switch
System Up Time (days,hour:min:sec): 00,02:32:55
System Contact:
System Name: switch0fdcfd
System Location:
System MAC Address: 68:bd:ab:0f:dc:fd
System Object ID: 1.3.6.1.4.1.9.6.1.83.10.2
switch0fdcfd#show version
SW version 1.1.1.8 ( date 30-Aug-2011 time 10:46:34 )
Boot version 1.0.0.4 ( date 08-Apr-2010 time 16:37:57 )
HW version V30
switch0fdcfd#show run
interface gi10
spanning-tree link-type point-to-point
exit
interface gi1
dot1x host-mode multi-sessions
exit
vlan database
vlan 100
exit
interface vlan 100
dot1x guest-vlan
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
dot1x system-auth-control
interface gi1
dot1x reauthentication
exit
interface gi1
dot1x mac-authentication mac-only
exit
interface gi1
dot1x guest-vlan enable
exit
interface gigabitethernet1
dot1x port-control auto
exit
interface vlan 1
ip address 192.168.10.22 255.255.255.0
exit
ip default-gateway 192.168.10.1
interface vlan 1
no ip address dhcp
exit
hostname switch0fdcfd
radius-server host 192.168.10.61 key 123456789 priority 2
radius-server key 123456789
aaa authentication dot1x default radius
no snmp-server server
ip domain name fred.com
ip name-server 209.18.47.61 209.18.47.62
ip telnet server
interface gigabitethernet10
macro description "switch | no_switch | switch"
exit
!next command is internal.
macro auto smartport dynamic_type switch
switchport trunk allowed vlan add 100
exit
switch0fdcfd#
If setup correctly, MAC based authentication works, so i have been told many times.
This obviously necessitates setting up the AAA server correctly, which i could not do
If you wish to progress your query further, please open a case with your distribution partner or the good folk at the Small Business Support Center (SBSC).
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
regards Dave
12-01-2011 06:17 AM
Thanks David,
David Hornstein wrote:
If setup correctly, MAC based authentication works, so i have been told many times.This obviously necessitates setting up the AAA server correctly, which i could not do
please understand that this is not what I expected as a qualified solution.
12-01-2011 06:29 AM
Sorry, I responded to your query because no one did, but, if you question if the switch MAC based authetication works, then open a case with the good folk at SBSC and work with them to resolve your query.
Sorry, gave the application a try, just do not have a full Radius server in my lab. :-(
regards Dave.
12-01-2011 07:08 AM
Hey, no problem I really appreciate your answer. Im now chatting with Borislav Atanassov, however he just told me that my Serialnumber is not under warranty. Very strange as the device specs say lifetime warranty...
12-02-2011 02:57 AM
Greetings Mr. Zacharias,
Today Boby and I configured this on our lab and this is our findings
we have a PC connected to port Gi1 without any 1x configuration
with the following switch config
switch3ba5e1#show run
vlan database
vlan 100
exit
interface vlan 100
dot1x guest-vlan
exit
interface gi1
exit
interface gi1
exit
interface gi1
exit
exit
interface vlan 1
ip address 192.168.1.254 255.255.255.0
exit
interface vlan 1
no ip address dhcp
exit
hostname switch3ba5e1
radius-server host 192.168.1.222 priority 1
radius-server key testing123
the only difference between Mr. Hornstein and ours is that he is running 1.1.1.8 and we are running 1.1.2.0
and we see the following on FreeRadius when the PC connect to port gi1
og expands to ../var/log/radius/radacct/192.168.1.254/reply-detail-20111202.log
modcall[post-auth]: module "reply_log" returns ok for request 1
modcall: leaving group post-auth (returns ok) for request 1
Sending Access-Accept of id 0 to 192.168.1.254 port 49181
Tunnel-Private-Group-Id:0 = "1"
Reply-Message = "Hello, c42c030e3ec7"
EAP-Message = 0x03010004
Message-Authenticator = 0x00000000000000000000000000000000
User-Name = "c42c030e3ec7"
Finished request 1
Going to the next request
Waking up in 6 seconds...
this is on the switch Side
this is our users.conf on the FreeRadius:
c42c030e3ec7 User-Password == "c42c030e3ec7"
Tunnel-Type:0 = "VLAN",
Tunnel-Medium-Type:0 = "IEEE-802",
Tunnel-Private-Group-Id:0 = "1",
Reply-Message = "Hello, %u"
Kindly share with us know your radius configuration, what firmware version you are running, a diagram of your topology, and your Switch configs
Thank you
Victor Cappuccio
Cisco Small Business Support
www.cisco.com/go/smallbizhelp
01-28-2012 06:54 AM
Hi Jan,
for me the Mac-Auth is working on SG300 firmware image 1.1.2.0.
When enabling this on the switch the switch send the MAC as "username" and as "password" in this format: "001122aabbcc". So for freeradius it is seen as a real 802.1X authentication type.
The CISCO isn't able to send just the calling-station-id (MAC) to freeradius like it is described here:
http://wiki.freeradius.org/Mac-Auth#Plain+Mac-Auth
My users file looks like this:
"000039e296ea" Cleartext-Password := "000039e296ea"
Tunnel-Type = VLAN,
Tunnel-Medium-Type = IEEE-802,
Tunnel-Private-Group-ID = "10"
Alexander Wilke
01-28-2012 11:43 PM
Hi Alexander,
Could you solve this problem, or you still have troubles with MAC based authentication and VLAN assignment? Because I have a working MAC-only based authentication here, I can send you the running configuration, and also the freeradius configuration for that.
Best regards,
Geza
01-29-2012 09:58 AM
Hi Geza,
I did not have any problems with that. I just want to say that it is working in my configuration. :-)
Not sure if the thread starter "jan.zacharias@dfki.de" could solve the problem.
Alexander
01-29-2012 10:16 AM
Hi Alexander and Jan,
I am sorry, I did not check that. But if Jan needs help with this, then of course my offer is valid for him too...
Best regards,
Geza
12-31-2014 09:45 AM
I'm currently in contact with Cisco because of exactly this issue.
Did someone make progress beyond what was reported here?
04-29-2013 06:20 AM
Sorry to revive a dead thread, but I am running into this same issue. It seems there is no way to configure this switch to perform only mac-based authentication. I was not able to find any way to change the behavior from sending the EAP messages to just sending the mac as username and password.
I am using freeradius but an implementation in another device that doesn't really allow me to change its configuration much. It is expecting fields 1 and 2 to be the MAC address for the username and password, and results in stating the EAP type doesn't match.
Login incorrect: [f0def1fb5f1d] (from client 192.168.5.100/32 port 1 cli F0-DE-F1-FB-5F-1D) [eap] Response appears to match, but EAP type is wrong. # Executing group from file /usr/local/etc/raddb/radiusd.conf rlm_perl: Added pair Auth-Type = EAP rlm_perl: Added pair EAP-Type = MD5-Challenge rlm_perl: Added pair NAS-Port = 1 rlm_perl: Added pair NAS-IP-Address = 192.168.5.100 rlm_perl: Added pair EAP-Message = 0x0201002204103c7ae7659aae20833d873898e4dd1906663064656631666235663164 rlm_perl: Added pair User-Name = f0def1fb5f1d rlm_perl: Added pair Message-Authenticator = 0x36bcd0966db5687cb7b20046dd9fcaf8 rlm_perl: Added pair State = 0x8e4e0f878e4f16419e6e1a8485d4a92d rlm_perl: Added pair Calling-Station-Id = F0-DE-F1-FB-5F-1D rlm_perl: Added pair NAS-Port-Type = Ethernet 2013/04/26 17:49:30 freeradius_hook[4627] INFO> main::authorize - performing authorize [<thread>] # Executing section authorize from file /usr/local/etc/raddb/radiusd.conf
did anyone else have any luck? Cisco Small Business team couldn't find a resolution either and just said it can't be done.
04-29-2013 11:22 AM
Hi Lannar,
you are actually the first person that understands the problem...
I think this will not be fixed as the linksys stuff is not maintained by cisco anymore.
Best luck patching your freeradius daemon.
04-29-2013 06:36 PM
It was my understanding that these small business switches are separate from the linksys product line, and as such are going to be continued to be developed/supported.. hopefully anyway.. its a relatively good product at a good price point, and I'd love to continue using them for our clients. The lack of full-blown iOS is frustrating however. the relevant command in a normal cisco device (mab) simply doesn't exist in this switch.
I spoke with the developer of my freedadius implementation, and it will cost me 5 days of R+D at $2000/day. Guess its time for me to move to a different switch.
