03-07-2022 12:45 AM
Dear ,
I have 2 questions regarding to SG350XG-24T firmware upgrade.
Question1, I have 2 SG350XG-24T switches which are in stack mode. If I upgrade the firmware , should I just operate from the Web UI to upgrade them as one switch ? or I need to upgrade each of the 2 switches individually ?
Question2, the present firmware version of SG350XG-24T is 2.0.0.73 , and the latest version is 2.5.8.15 , can I upgrade directly from 2.0.0.73 to 2.5.8.15 ? Do I need to upgrade to a transitional version first ?
Many thanks .
03-07-2022 01:23 AM
Question 1 - you can upgrade whole stack 1 upgrade.
Question2. - as per i know upgrade to 2.5 is straight forward .
Note : make sure you read the release notes of target firmware see any caveats.
03-09-2022 01:28 AM
Hi Balaji ,
Many thanks for you reply, really helps me
I reed below release note, should be straight forward as you told from 2.0.0.73 to 2.5.8.15,
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/350xg/rn/b_tesla-release-2_5_8_15.pdf
We will schedule a upgrade and update this post when upgrade is done, thanks
03-09-2022 04:44 AM
sure please give us feedback...good luck.!
