08-09-2021 08:53 AM
Hi Community,
I didn't find anything about it, so I would like to know if SMB switches supports Vlan ACL/Vlan Access Map.
Thank you
Solved! Go to Solution.
08-10-2021 07:43 AM
Sx110/CBS110 series switches are unmanaged. Sx250/CBS250/Sx350/CBS350/Sx550 do support VLAN ACL binding. You can refer to our online device emulator and see the full feature-set functionalities.
08-09-2021 09:06 AM
waht model of swich example ?
not sure this help you (just check)
08-09-2021 09:08 AM - edited 08-09-2021 09:12 AM
Not yet, it is not define.
I just want to know if one of the switches propose this feature.
Thank you for the link, that confirm that Sx350 Series support VLAN ACL. Any idea about the others (SMB110, 250, 1000)
Thank you
08-10-2021 07:43 AM
08-11-2021 06:18 AM
Thanks a lot for your help @Martin Aleksandrov
The tool is also helpful !
08-12-2021 04:22 AM
you're welcome!
Basically with the online device emulators, one can see all the features our devices support. Switches web GUI covers 100% of the CLI command line functionalities and routers and APs have only web GUI to administer.
Martin
08-10-2021 01:40 AM - edited 08-10-2021 01:41 AM
Please anyone else to know if Vlan ACL/Vlan Access Map is supported on SMB switches products ?
Thank you
