05-23-2022 03:35 AM
I have a cisco switch (model SG300-52P), I use it to connect IP security cameras to Network Video Recorder (NVR). Some ports do not work with some cameras (especially the first ones in numbering 1 to 5). But the same cameras work fine with other ports? These problem ports 1 to 5 show operational status down? I do not know why they are down? When I plug other cameras with a short cable near switch in these ports 1 to 5 they go up?
05-23-2022 03:41 AM
- Check logs , if these get connected to the none working ports. also then check interface status , and counters (e.g.)...
M.
05-28-2022 01:43 AM
Thanks, appreciate explaining more on "Check logs" and interface status and counters? how they affect this and how to resolve the issues.
05-23-2022 03:47 AM - edited 05-23-2022 03:48 AM
Make sure you have enough power. I already worked in a situation where some cameras did not work because switch could not deliver power to all camera. Newer cameras with high quality images, consume lot more power to work (30W sometimes).
You need to do the math considering your Power supply capacity and divide by the switch port number times the Camera requirement.
Another option is a faulty switch as well.
05-23-2022 05:05 AM
I also experienced similar issue a years ago. I would recommend to change power source and try again. I hope you cables and connectors are as per standard and in good condition. You have not to cross recommended cable length too.
05-28-2022 01:46 AM
Thanks, change power source for the switch itself or the cameras?
