08-21-2020 11:14 AM
My company has deployed a lot of SG350, SG350X, and SG550X switches in the past (we are a A/V integrator). I am trying to grasp the fundamental differences between these 2 new lines of switches (CBS250 vs. CBS350).
I see the CBS250 line has 10G SFP options now, and wondring what I am leaving on the table if I start building networks from the CBS250 line of options.
I am HAPPY to read a white paper on the topic, but after an hour looking through the cisco.com website I have yet to find any information specific to this question. TIA
08-24-2020 11:50 PM
Hi there,
The CBS350 48 port can supply up to 740W of POE power. All models of CBS350 support sFlow and switch stacking.
cheers,
Seb.
08-25-2020 08:18 AM
So does that mean there is NO OTHER difference between the CBS250 and CBS350 products lines? It would seem to me there would be quite a few other differences in the way I assume there are many differences between the SG250 and SG350 lines of current switches. Its surprisingly hard to find a concise list of features and capabilities and differences between the SG250 and SG350 switch lines, even though those have been out for quite some time now.
08-27-2020 01:04 AM
Hello again,
Take a look at this document:
..it is marketed to show the key differences between them platforms. I'd agree there isn't much here, but when the price points are so close there isn't really going to be much between them.
cheers,
Seb.
12-09-2020 04:25 AM
Can we do stacking with SG350 and CBS350 ?
or SG with CBS switches?
12-09-2020 05:38 AM
Hello Mohammad,
Cross stacking between SG350 switches and the latest generation of CBS350 series is not supported.
Martin
12-09-2020 06:26 AM
Thanks For your prompt response.
Do they have different ASCIC hardware chipset ? major difference on Chipset side?
12-09-2020 09:09 AM
Hi Mohammad,
The CBS350 series have improved next-generation Network ASIC.
Martin
09-30-2020 02:35 AM
Main differences I recognized:
| CSB250 | CSB350 | |
| PoE | Tak 370W (48 port) | Tak 740W (48 port) |
| MAC table | 8k | 16k |
| VLANs | 255 | 4094 |
| IGMP 1,2,3 | up to 255 multicasts | up to 2k multicasts |
| ACL | 512 rules | 1024 rules |
| stackable | no | yes (10G models) |
| sFlow | no | yes |
09-10-2021 08:19 AM
Really, no stacking of CBS250-24p-4X switches at all?
What are the 10G SFP+ ports for, if I cannot connect to a second CBS250-24p-4X?
I just want to connect two switches together with 10G fiber tranceivers, to be faster than with 1GbE with standard copper cable!?
Now I have to think if the CBS250 were a bad buy...?!
09-10-2021 09:46 AM
09-14-2021 03:33 AM
I use SFP+ trancievers from 10Gtek, they told me that these are compatible with CBS250-24P-4X...
Or is this not true?
I moved further details of my problem to a new topic:
09-14-2021 03:56 AM
09-14-2021 06:16 AM
Okay, reasonable, but if I order/buy/get new official supported tranceivers next days/week, will it work out-of-the-box, i.e. establish the interconnection without any settings in the switch-OS? Of do I have also again to enable the SFP+ ports or similar beforehand? If yes, please tell me what to do.
09-14-2021 06:30 AM
