07-30-2019 07:33 AM
Hello, I originally had 2 3850 12S in a two stack switch using smart stack cables. I separated the stack, removed the cable deleted the switch2 provision statement and the vlan.dat, did a write erase.
Now when I reboot the second switch I have Gi2/0/1 - 12 showing instead of Gi1/0/1 - 12.
How can I get this back to the defaults of Gi1/0/1 - 12?
Solved! Go to Solution.
07-31-2019 12:15 AM
@JavaJunkie wrote:
This does not work. "No such resource"
The command "switch 2 renumber 1" can only be used in ENABLE mode (and not configuration mode).
07-30-2019 07:37 AM
use the switch renumber command, that will get you there.
07-30-2019 07:41 AM
07-30-2019 10:00 AM
This does not work. "No such resource".
Any other ideas?
Thanks for the reply
07-30-2019 10:56 AM
07-30-2019 06:03 PM
Switch 2
07-31-2019 12:15 AM
