vlan issue
Anthonylilomba
Hi everyone,
I use SG350X-24MP Switch: I've set 6 VLANs and 2 XG trunk port. No Vlan can reach one another, I need to isolate every VLAN and no Vlan routing is needed.
Here is My problem:
I need to configure a special port (interface) on witch I can connect my Wake-on-LAN Linux Server or my printer.
How can I configure that interface in a manner that all my Vlans can reach it but they can't communicate between theh all?
What vlan type or mode can I used to set my interface for that purpose or another solution??
I'm searching for a switching solution, a LAN solution only (no routing, no ACL at all!!)
Can somebody help me???
I've found the solution !!! ... Just to set a interface as a trunk in
particular Vlan in tagged mode. The result is that all other vlans can
reach it and get connected to it without beiing connected between them
all.
luis_cordova
Hi @Anthonylilomba ,
To achieve communication intervlan (for the printer), you must enable IP routing.
That will lead to you having to enter some ACL to allow access only to the IP of the printer.
all.
