01-22-2021 04:48 PM
I'm struggeling here... So! Here is how it works : I have 6 cisco SG350-20 switches daisy-chained. On the fourth of the line I have interpretation system that needs to send data on receivers connected to the other switches (1 receiver per switch). First, I set ports 8 and 16 to the default vlan as trunks on all the swtiches (to make sure the signal goes through between all the swicthes). Then I created 5 vlans (on the fourth switch) to send my 5 signals to the other switches. Then on the other switches I created one VLAN to "connect" to the same VLAN ID of the fourth switch. The signal doesn't goes through, what am I missing?
THank you !
Solved! Go to Solution.
01-22-2021 10:32 PM
- Note that these devices do not support VTP. Any (new) VLAN needed must be created on each device involved.
M.
01-22-2021 10:32 PM
M.
