What is the term length command for SG switches?
MichaelWalk5819
I know the term length commands for a catalyst, but SG switches don't have a term length command.  So how do I get the output to pause so I can read it?  Like when I do a sh tech-support it scrolls all of the info off the screen, how can I get it to pause in between so I can read it for SG switches.
Deepak Kumar
Have you tried: terminal datadump command?
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
No because I want the pause.
Would the command be no terminal datadump?
Sujoy Paria
Hi Michael,
As of now terminal length command is not available for SG switches however capturing the tech-support output to a text file is one option you may try, in case that helps you to review the output. One common application is putty for that purpose.
