06-22-2021 02:53 PM
We replace a Cisco 3750 switch with a new Cisco 9200 switch.
We have an SFP 1000base-SX works well with the 3750. When we move it to Cisco 9200, the switch doesn't like it.
The error is err-disabled.
The new 9200 is:
C9200-24P
IOS is CAT9K_LITE_IOSXE
version 17.03.03
Another thing, I know 1000BaseLX SFP work with this switch. Do you think if it is OK to use 1000BaseLX SFP instead of 1000base-SX?
Loc
06-22-2021 03:17 PM
@Loc Nguyen : Check all compatible SFP's for this switch on below link, If it is not there then it is not supported
06-22-2021 04:02 PM
SFP 1000base-SX
is this cisco what is the product full code.
LX/LH for the single more Long haul, SX is Multimode short-range, depends on cable you can connect SFP optic.
06-22-2021 05:07 PM
@Loc Nguyen : Well @balaji.bandi is correct, you put the wrong code, Please share the correct one and i will update you if it is supported or not !
Inderdeep Singh
www.thenetworkdna.com ( Awarded by Cisco IT Blogs award 2020)
