2821 hardware compatibility
danletkeman
I'm looking at putting in some WIC-1ADSL cards into a 2821 router. I
would need to put in 6 of them, but the 2821 only has 4 onboard slots
and I was wondering if the NM-2E2W is compatible with a 2821 router so
I can add the last two?
Dan.
Leo Laohoo
mariano.deheza
Hello!
I have two routers, Cisco 2811 and 2821, and want to add two extra eth ports. So one alternative is the NM-2E2W, I would like to know if this board is supported by that routers.
Somebody answered your question, but he misinterpreted the model, I think. Kind regards, Mariano
Hello Brad, thank you for your quick response.
I thought that could be compatible because in Packet Tracer, the NM-2E2W appears as available, and works, for the 2811.
Thank you!
Kind regards,
Mariano
