2950 Switch not allowing me to set up SSH?
jpedersm1
After setting up the domain name I try to use the crypto key and it is no where to be located, any ideas if there is something wrong?  Below is some of the information I copied from TeraTerm
Switch-1(config)#ip domain-name justin.lab.com
Switch-1(config)#cry
Switch-1(config)#cry?
% Unrecognized command
Switch-1(config)#crypto key ?
% Invalid input detected at '^' marker.
Switch-1(config)#?
Configure commands:
  aaa                         Authentication, Authorization and Accounting.
  access-list                 Add an access list entry
  alias                       Create command alias
  arp                         Set a static ARP entry
  banner                      Define a login banner
  boot                        Boot Commands
  buffers                     Adjust system buffer pool parameters
  cdp                         Global CDP configuration subcommands
  clock                       Configure time-of-day clock
  cluster                     Cluster configuration commands
  cns                         CNS agents
  default                     Set a command to its defaults
  default-value               Default character-bits values
  define                      interface range macro definition
  do                          To run exec commands in config mode
  dot1x                       Dot1x Global Configuration Commands
  downward-compatible-config  Generate a configuration compatible with older
                              software
  enable                      Modify enable password parameters
  end                         Exit from configure mode
  errdisable                  Error disable
--More--
And here is the version on the switch
witch-1#show version
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA14, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by cisco Systems, Inc.
Compiled Tue 26-Oct-10 10:35 by nburra
Image text-base: 0x80010000, data-base: 0x80570000
ROM: Bootstrap program is C2950 boot loader
Switch-1 uptime is 2 hours, 11 minutes
System image file is "flash:/c2950-i6q4l2-mz.121-22.EA14.bin"
cisco WS-C2950-24 (RC32300) processor (revision J0) with 20956K bytes of memory.
Processor board ID FHK0719Z1R8
Last reset from system-reset
Running Standard Image
24 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0D:28:2B:AB:80
Motherboard assembly number: 73-5781-11
Power supply part number: 34-0965-01
Motherboard serial number: FOC0719078W
Power supply serial number: DAB07195C7Q
Model revision number: J0
Motherboard revision number: A0
Model number: WS-C2950-24
System serial number: FHK0719Z1R8
Configuration register is 0xF
6 Replies 6
SOcchiogrosso
Level 4
Level 4
Doesn't appear tone a k9 image if an image is not k9 it does have much in the way of encryption. Upgrade the iOS is applicable to a k9 image
-- CCNP, CCIP, CCDP, CCNA: Security/Wireless Blog: http://ccie-or-null.net/
Is there any way to find out if it is a k9 or not.  If it is just updating the is what version would support it?
I believe the image you are after is this one:
c2950-i6k212q4-mz.121-22.EA14.bin - C2950 EI and SI IOS Crypto Image
I guess I should have asked this before but where can I get these?
  Normally you need a cisco contract to download the ios. Seeing that those switches are end of life I'm not sure how you would get an SSH version.  Try this url and contact cisco and ask them how to get the last sssh version they made for that model.
http://www.cisco.com/web/siteassets/contacts/international.html#~tab-c?reloaded=true
jpedersm1
Thank you. I got these off eBay for help with my CCNA studies so that's us why I'm still using them.
