2950 switches
DarrylBaker
Beginner
Beginner
how to backup ios for 2950 switch to a tftp server
syed kazim abbas
Participant
Participant
hi darry,
if you are know how to take backup ios of routers then you need only one step more needed:
Verify the switchport where TFTP server  connected , in which vlan it is existed.
for example in vlan 1
interface vlan 1
no sh
ip add 10.1.1.1 255.255.255.0   (10.1.1.2 ip of tftp server)
exit
ping 10.1.1.2
now its ok, you can take backup
switch#sh flash
System flash directory:
File  Length   Name/status
  3   33591768 c2950-advipservicesk9-mz.124-15.T1.bin
  2   28282    sigdef-category.xml
  1   227537   sigdef-default.xml
[33847587 bytes used, 30168797 available, 64016384 total]
63488K bytes of processor board System flash (Read/Write)
Switch#copy flash: tftp
Source filename []? c2950-advipservicesk9-mz.124-15.T1.bin
Address or name of remote host []? 10.1.1.2
Destination filename [c2950-advipservicesk9-mz.124-15.T1.bin]? new_file_name
kazim
"please rate and select as correct answer if post helpful"
