2960-X
Docklands
Level 3
Level 3
Can you assign an IP address to an SVI on the 2960-X.
If not, can it be configured with a management address?
6 Replies 6
Bilal Nawaz
Yes you can assign IP to SVI on 2960x
You can also configure management port
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Thank you for the reply.
Out of interest where can you find information on the other features available on the 2960X?
I tried the Cisco Navigator but it doesn't seem to work.
The IOS we are looking at is the LAN Base 15.2.2E5 MD
What spesific feature are you looking for?
Here is a link to the data sheet and supported features:
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/data_sheet_c78-728232.html
We need to know what features/commands are available with LAN Base 15.2.2E5 MD.
The Cisco Navigator site does not provide any information for this IOS when used with the 2960X
I hope this will help you
http://www.cisco.com/c/en/us/support/switches/catalyst-2960-x-series-switches/products-installation-and-configuration-guides-list.html
Thank you Bilal.
I think until the Cisco Navigator is working properly this is the best information available.
