2960S trunking issue after IOS upgrade.
richard klein
I have done this a few times and am missing something but cant figure out what it is. I think I should have set Gi2/0/1 with trunk for Vlan 1 & 50 - it shows no trunk at all.
Any ideas what i am doing wrong?
Thanks, Rich
Booting off of: c2960s-universalk9-mz.150-2.SE12.bin
User Access Verification
Password:
Switch>enable
Password:
Switch#show vlan
Switch#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)#vlan 50
Switch(config-vlan)#exit
Switch(config)#exit
Switch#show vlan
VLAN Name Status Ports
1 default active Gi2/0/1, Gi2/0/2, Gi2/0/3
50 VLAN0050 active
1002 fddi-default act/unsup
Switch#conf t
Switch(config)#int Gi2/0/1
Switch(config-if)#switchport mode trunk
Switch(config-if)#switchport trunk allowed vlan 1,50
Switch(config-if)#end
Switch#show int trunk
Switch#
If I try
Switch#show interfaces gi2/0/1 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: 1,50
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Switch#show interfaces gi2/0/14 switchport
Switchport: Enabled
Administrative Mode: dynamic auto
Operational Mode: down
Voice VLAN: none
Trunking VLANs Enabled: ALL
Capture VLANs Allowed: ALL
Port 1 will have both Vlan 1 & Vlan 50 trunking - Port 14 says all Vlan enabled but Vlan 50 doesnt actually work.
I have a Ubi wifi access point looking for Vlan 1 & 50 - it works on Port 1, but not port 14.
In the past prior to this upgrade it would work with the top commands.
What am I doing wrong?
Rich
6 Replies 6
balaji.bandi
Try this
config t
interfaces gi2/0/14
switchport access vlan 50
end
test it
BB
Wouldnt that make the port only access Vlan50?
Should I do a factory reset on the switch (how do i do that?)
If you looking to port to be in Access vlan that command i gave you to work ?
But you looking for trunk ? as suggested on other post can you post full configuration.
BB
The port is down. Is anything connected to it?
Leo Laohoo
Post the complete output to the command "sh interface G1/0/14 controll".
Password:
Switch>enable
Password:
Switch#sh interface gi2/0/14 control
GigabitEthernet2/0/14 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is e840.405c.3e8e (bia e840.405c.3e8e)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 01:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
256 packets input, 58541 bytes, 0 no buffer
Received 99 broadcasts (28 multicasts)
0 watchdog, 28 multicast, 0 pause input
3216 packets output, 371894 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Transmit GigabitEthernet2/0/14 Receive
372214 Bytes 58541 Bytes
377 Unicast frames 157 Unicast frames
697 Multicast frames 28 Multicast frames
2147 Broadcast frames 71 Broadcast frames
0 Too old frames 45541 Unicast bytes
0 Deferred frames 2468 Multicast bytes
0 MTU exceeded frames 10452 Broadcast bytes
0 1 collision frames 0 Alignment errors
0 2 collision frames 0 FCS errors
0 3 collision frames 0 Oversize frames
0 4 collision frames 0 Undersize frames
0 5 collision frames 0 Collision fragments
0 6 collision frames
0 7 collision frames 69 Minimum size frames
0 8 collision frames 115 65 to 127 byte frames
0 9 collision frames 16 128 to 255 byte frames
0 10 collision frames 29 256 to 511 byte frames
0 11 collision frames 8 512 to 1023 byte frames
0 12 collision frames 19 1024 to 1518 byte frames
0 13 collision frames 0 Overrun frames
0 14 collision frames 0 Pause frames
0 15 collision frames
0 Excessive collisions 0 Symbol error frames
0 Late collisions 0 Invalid frames, too large
0 VLAN discard frames 0 Valid frames, too large
0 Excess defer frames 0 Invalid frames, too small
2184 64 byte frames 0 Valid frames, too small
529 127 byte frames
170 255 byte frames 0 Too old frames
265 511 byte frames 0 Valid oversize frames
57 1023 byte frames 0 System FCS error frames
16 1518 byte frames 0 RxPortFifoFull drop frame
0 Too large frames
0 Good (1 coll) frames
0 Good (>1 coll) frames
Switch#
