2960S, WS-C2960S-STACK, cables?
mozmorris1974
im looking to purchase a couple of
WS-C2960S-48LPS-L
or
WS-C2960S-24TS-L
and stack them using
WS-C2960S-STACK
do they come with stacking cables? or will they have to be purchased separately?
im used to 3750's that come with the stacking cables.
Thankyou
5 Replies 5
Collin Clark
When you purchase that stack module you get a 0.5M (50cm) stack cable with it.
Hope it helps.
thank you very much Collin
Hi Morris,
The below mentioned are the part-code of the stack cables. By default when you purchase a switch you will get 0.5M stack cable.
If you want a longer stack cable, then you should order for it by using the part id mentioned below.
The maximum length would be 3 metres.
Cisco Catalyst 2960-S FlexStack stacking cables:
1. CAB-STK-E-0.5M FlexStack stacking cable with a 0.5 m length
2. CAB-STK-E-1M FlexStack stacking cable with a 1.0 m length
3. CAB-STK-E-3M FlexStack stacking cable with a 3.0 m length
Hope this helps
Cheers
Somu
Rate helpful posts
Thanks Collin, helpful info
Dennis Mink
If you are going to stack like 4+ you will need to order the longer stack cables separately, cause .5 meter aint gonna stack much
Please remember to rate useful posts, by clicking on the stars below.
