03-14-2022 10:35 PM
Does anyone know if there are any intermediary updates that are required to move from 15.2(2)E7 to 15.2.7E5 MD on a WS-C2960X-24TD-L?
03-14-2022 10:41 PM
no you can directly upgrade.
03-15-2022 12:03 AM
Direct upgrade to 15.2(7)E5 is supported/allowed, however, I strongly recommend a cold reboot (pull the power cable) so the upgrade can be done "cleanly".
IMPORTANT: Expect a mandatory ROMMON/micro-code upgrade. This will add, approximately, 14 minutes on top of the reboot.
03-15-2022 12:26 AM
I have seen many micro-code upgrades take around 30-40min. Just so you dont get scared when your switch is offline for up to 45min in total.
09-15-2022 08:41 PM
I am going from 15.2(7)E2 to 15.2(7)E5
This should be allowed direct path - yes?
09-15-2022 08:53 PM
Read my previous response (LINK).
09-15-2022 08:57 PM
Thanks Leo. No one will be onsite - therefore a reload is all I can do since we are an MSP and do everything remotely in the middle of the night for the client.
I have done a handful of E3 ->E5 remotely with no issues. But I understand where you are coming from.
10-16-2023 05:08 AM - edited 10-16-2023 05:10 AM
Hi guys,
I'm facing with a problem during upgrade from 15.2(2)E5 to 15.2(7)E5.
after boot has been set and we are going with the reload then the swtch goes to Rommon mode what we should do next ? cold reebot ?and then it will boot correctly ?
10-16-2023 05:00 PM
Console into the switch and reboot.
Post the entire boot-up process.
05-28-2025 04:57 PM
Hello again I am going from 15.2(7)E9 to 15.2(7)E12 on a 4 stack of 2960x-48-FPD-L
This should not be a problem, correct?
05-28-2025 05:46 PM
Should not be a problem if the switches are genuine.
05-28-2025 06:10 PM
You bet Leo, authentic Cisco brand for sure...
