3650 Power Supply Disabled
Cisco1619
I am having an issue that I can't seem to resolve. Has anyone had an issue where good power supplies show "disabled" on WS-C3650-48FS-L switches? I have 2 stacks that show power being disabled on some of the power supplies. It is currently running code version 03.06.06E. I have tried the EXEC command "power supply 1 slot b on" but it didn't resolve the issue. Reboots did not help either. Has anyone experienced this before? Thanks for any help.
SW-3650-F8#sh environment power all
SW--PID-------------------------Serial#-------------Status-------Sys Pwr------PoE Pwr---------Watts
1A-- PWR-C2-1025WAC--- xxx1949xxxx----- OK---------- Good--------- Good------------ 1025
1B-- Unknown----------------- Unknown---------- Disabled-- Good--------- Good------------ 235
2A-- PWR-C2-1025WAC--- xxx1949xxxx----- OK---------- Good--------- Good------------ 1025
2B-- PWR-C2-1025WAC--- xxx1949xxxx----- OK---------- Good--------- Good------------ 1025
3A-- PWR-C2-1025WAC--- xxx1949xxxx----- OK---------- Good--------- Good------------ 1025
3B-- Unknown----------------- Unknown---------- Disabled-- Good--------- Good------------ 235
4A-- Unknown----------------- Unknown---------- Disabled-- Good--------- Good------------ 235
4B-- PWR-C2-1025WAC--- xxx2024xxxx----- OK---------- Good--------- Good------------ 1025
5 Replies 5
Reza Sharifi
I have seen the same thing with 3850 series where the Power supply is working fine but show environment command shows it as disable or unknown. This also causes the monitoring software to get confused and send alerts. This is an IOS bug, and so you may want to open a ticket with TAC and see if they have an image that does not have this problem.
bug has been documented under CSCvn40414.
Cat3650-PSU shown as Disabled when there is not input power cables.
sagar.parikh49
Disabled
The power supply and input power are present, but power supply is switched off by CLI.
Switch# power supply 1  slot A on/off----------> use this command for doing on/off the power supply
murisonchuck
I also have this problem on a 3650 running 16.3.3 which also has a memory leak.  We will be upgrading next week.
bensonlei
Catalyst 9300 is found also this problem:
Catalyst 9300 switch : FRU power supply B powered off ( Status --- Disabled ) - Cisco Community
The onsite engineer also reported the RED/AMBER LED was blinking while he reached at the spot.
" Disabled :  The power supply and input power are present, but power supply is switched off by CLI. "
Switch issues this command automatically when it finds supply problem, thx  ?
