3650 vs 3750
bkoum
hi
may i ask which switch support tha latest IOS ver between those models ?
and generaly if there is any significant differance ?
thanks
Danilo Dy
Check this Software Feature Comparison between 3560-E and 3750-E for IOS 12.2(35)SE2 http://www.cisco.com/en/US/products/ps7077/networking_solutions_products_generic_content0900aecd805f0eaf.html
Dandy
shrikar.dange
hi,
You can find the comparison on this link under swictches-->LAN SWITCHES section:
http://www.cisco.com/web/psa/products/index.html
HTH,
regards,
shri :)
Danilo Dy
Dandy
The link provided by Dandy is very comprehensive, practically speaking the main difference between them is the stacking ability which only the 3750 supports, the switch performance and the switch fabric are the same:
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/switchperformance.pdf
BR,
Mohammed Mahmoud.
