POST: ILP Controller Tests
rbreidenstein
Community Member
posted below is the output from the post. I then receive an output stating.
!!! WARNING: The switch is not usable !!!
I searched on google and on ciscos site for information even on ILP Controller and nothing comes back.... any suggestions?
The system light is orange.
POST: ILP Controller Tests : End, Status Failed
INIT: failed ILP accessing test
rbreidenstein
Community Member
could it mean In Line Power? but why would that cause the whole switch to fail?
Rick,
That's a Power on Self-Test POST failure. Its related to inline power controller hardware failure. Please go ahead and raise an RMA request, its a hardware failure on the box.
HTH,Please rate if it does.
-amit singh
Thanks for your help, it really helps, I am facing same issue with my switch.
regards
karuna
