3750 Inter-VLAN Routing
xion824cjc
Need a little help on this one. I am using a Catalyst 3750 for my L3 switch. I need to add 4 servers in one subnet to a VLAN, and 4 other servers in a different subnet to a second VLAN, then configure the switch to provide routing between the two VLANs. I am simulating my company's disaster recovery solution in a lab environment. Any help would be GREATLY appreciated! This is driving me nuts!
8 Replies 8
glen.grant
It should look like this .
ip routing
int vlan 2
ip address 192.168.2.254 255.255.255.0
no shut
in vlan 3
ip address 192.168.3.254 255.255.255.0
no shut
to put interfaces into vlan
int g1/0/1
switchport access vlan 2
int g1/0/2
switchport access vlan 3
Here's an example, hopefully you can clarify a little bit on what commands I run.
Say I have VLAN 2 (IP's 160.190.100.20-23) and VLAN 3 (IP's 20.20.90.10-13). VLAN 2 is on ports 1-4, and VLAN 3 on ports 13-16.
Would I have to run int g1/0/1-4 with the switchport access vlan 2 command, or 3 command? And do I do that on all ports?
Sorry, I'm fairly new Cisco equipment. not quite sure how to do all this. I have the VLANs configured with the 8 systems (4 in each of the 2 VLANs). Just don't know how to move on from there.
If a host IP falls within your VLAN 2 IP range, then it's port should be given the following commands:
switchport mode access
Same applies to host IPs within your VLAN 3 range.
I'm not sure what size subnets you are running but assuming the following:
VLAN 2 = 160.190.100.0/27
VLAN 3 = 20.20.90.0/27
On your L3 switch:
ip routing
int vlan 2
ip address 160.190.100.1 255.255.255.224
no shut
int vlan 3
ip address 20.20.90.1 255.255.255.224
no shut
to place interfaces into the appropriate VLAN
int range g1/0/1 - 4
int range g1/0/13 - 16
Assuming your hosts are plugged into your L3 switch, the VLANs will be created once you assign ports to them without you having to create them through other commands. You should see a message similar to "VLAN 3 does not exist, creating VLAN 3" or something like that. Verify that they were actually created with the show vlan command.
Ok...So in the
int vlan 2
no shut
int vlan 3
no shut
the ip addresses 100.1 and 90.1 are my gateway addresses, correct?
Hi Friend,
Yeah you got it right!!
IP 160.190.100.1 will be gateway for your machines which are in vlan 2
IP 20.20.90.1 will be the gateway for your machines which are in vlan 3
Ankur
*Pls rate all helpfull post
Ok. I must be doing something wrong. I still cannot get this to work. Here's the setup. Maybe this can help:
Vlan 2
sys 1 - 160.190.100.20 255.255.255.0
sys 2 - 160.190.100.21 255.255.255.0
sys 3 - 160.190.100.22 255.255.255.0
sys 4 - 160.190.100.23 255.255.255.0
vlan 3
sys 1 - 20.20.90.10 255.255.255.224
sys 2 - 20.20.90.11 255.255.255.224
sys 3 - 20.20.90.12 255.255.255.224
sys 4 - 20.20.90.13 255.255.255.224
All systems connected directly to the 3750. VLAN 2 ports 1-4, VLAN 3 ports 13-16. None of the systems have a default gateway.
I've attached a MS Word doc showing the commands I'm running. Can someone help me sort through this please? Thanks for all the great help everyone!
please configure default gateway on systems otherwise servers in one VLAN will not be able to communicate with servers in second VLAN.
so, servers in VLAN 2 will be configured with 160.190.100.1 while servers in VLAN 3 will be configured with 20.20.90.1 as default gateway.
secondly, in your document, you mentioned that while configuring VLAN 2, you get message saying it overlaps VLAN 1, so probably if you are not using VLAN 1, shut the interface like this.
interface vlan 1
shutdown
try to ping between PCs which are in different VLAN and let us know with the results.
Your client nics must have their default gateway pointed to the router address of the vlan they are attached to.
