3750 Interface Total output drops incorrect
Jay Chang
Community Member
I am seeing Interface output drops that appera to be incorrect.  When I do "Show Interface gi1/0/20", I will get interface output drops of "4294961382
".  But, when I do the same command again it shows "0" drops.  Is this a reporting error? I am ruinning c3750-ipservicesk9-mz.122-58.SE.bin on a 3750 stack with 2 switches in the stack.  Thanks.  Below is the output from the command line.
FC-InetSR3750E#sh int gi1/0/20
GigabitEthernet1/0/20 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 001e.bd47.2ac1 (bia 001e.bd47.2ac1)
  Description: To-FC-PIXGUEST port E1
  Internet address is 8.4.226.225/30
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 3/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:07:42, output 00:00:33, output hang never
  Last clearing of "show interface" counters 00:30:01
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 4294961382
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 453000 bits/sec, 228 packets/sec
  30 second output rate 1403000 bits/sec, 253 packets/sec
     491221 packets input, 118749636 bytes, 0 no buffer
     Received 1 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     631901 packets output, 526432525 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
FC-InetSR3750E#sh con
FC-InetSR3750E#sh int gi1/0/20 coun
FC-InetSR3750E#sh int gi1/0/20 counters error
Port        Align-Err     FCS-Err    Xmit-Err     Rcv-Err  UnderSize  OutDiscards
Gi1/0/20            0           0           0           0          0            0
Port      Single-Col  Multi-Col   Late-Col  Excess-Col  Carri-Sen      Runts     Giants
Gi1/0/20           0          0          0           0          0          0          0
     reliability 255/255, txload 5/255, rxload 1/255
  Last input 00:08:20, output 00:00:12, output hang never
  Last clearing of "show interface" counters 00:30:39
  30 second input rate 507000 bits/sec, 291 packets/sec
  30 second output rate 2076000 bits/sec, 341 packets/sec
     501499 packets input, 120921373 bytes, 0 no buffer
     643994 packets output, 535787896 bytes, 0 underruns
10 Replies 10
andtoth
Level 9
Level 9
Hi Jay,
You are hitting the following known software defect: CSCso81660 - 3750 stack shows incorrect values for output drops
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCso81660
Symptom:
3750 stack shows incorrect values for output drops on show interfaces
Conditions:
This is seen on 3750 G stacks running 12.2(44)SE or 12.2(44)SE1.
Workaround:
none
Further Problem Description:
The 'show platform port-asic stats drops' shows the correct values.
The issue is causing interoperablity issue with SNMP
This has been fixed in version 12.2(46)SE and 12.2(50)SE.
Best regards,
Andras
I am using 12.2.58SE.  Does this version have the same bug?
FC-InetSR3750E#sh ver
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(58)SE, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 05-Apr-11 08:31 by prod_rel_team
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
FC-InetSR3750E uptime is 3 weeks, 4 days, 20 hours, 43 minutes
System restarted at 20:04:20 summer Thu Apr 21 2011
System image file is "flash:c3750-ipservicesk9-mz.122-58.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html you require further assistance please contact us by sending email to
export@cisco.com. WS-C3750G-24PS (PowerPC405) processor (revision F0) with 131072K bytes of memory.
Processor board ID FOC1149Y54J
Last reset from power-on
6 Virtual Ethernet interfaces
56 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
If
cisco
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:1E:BD:47:2A:80
Motherboard assembly number     : 73-10217-07
Power supply part number        : 341-0108-03
Motherboard serial number       : FOC11492F08
Power supply serial number      : AZS11491335
Model revision number           : F0
Motherboard revision number     : B0
Model number                    : WS-C3750G-24PS-E
System serial number            : FOC1149Y54J
Top Assembly Part Number        : 800-27482-01
Top Assembly Revision Number    : C0
Version ID                      : V05
CLEI Code Number                : CNMWT00ARC
Hardware Board Revision Number  : 0x09
Switch Ports Model              SW Version            SW Image
     1 28    WS-C3750G-24PS     12.2(58)SE            C3750-IPSERVICESK9-M
*    2 28    WS-C3750G-24PS     12.2(58)SE            C3750-IPSERVICESK9-M
Hi Jay,
If the output drops value is continously changing between 0 and a high value, it seems to be a software defect. I did not find known issues for 12.2(58)SE. I would recommend you to open a TAC case for this.
Best regards,
Andras
Hi Jay,
Beside the equipment output, do you really EXPERIENCE traffic drops?
I don't experience any drops that I know of.  All the applications seem to be working fine.
Hi Jay,
This seems to be a cosmetic issue (drops are only reported in 'sh interface' output) as well as in defect CSCso81660 which is indeed fixed already in 12.2(58)SE, so it's likely another issue.
I would recommend contacting TAC to track this and investigate further to find out if a new defect has to be opened.
Best regards,
Andras
I have a stack of two -12S and the following apparent high drops.
QoS is not enabled.
Traffic - that is very moderate - flows normally. Running 12.2(50)SE3 and SE5.
Also seeing the same problem on 2960S, 3560 in the same network. all on gigabit interfaces.
Basically, we're unble to tell what are real drops and what are not, altough I suspect the figures on Port-channel interfaces are correct.
What is your opinion or advice ?
FG-SW-CORE#sh int summ
*: interface is up
IHQ: pkts in input hold queue     IQD: pkts dropped from input queue
OHQ: pkts in output hold queue    OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec)          RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec)          TXPS: tx rate (pkts/sec)
TRTL: throttle count
  Interface               IHQ   IQD  OHQ   OQD  RXBS RXPS  TXBS TXPS TRTL
  Vlan1                    0     0    0     0     0    0     0    0    0
* Vlan2                    0     0    0     0  5000    2     0    0    0
* Vlan3                    0     0    0     0     0    0     0    0    0
* Vlan4                    0     0    0     0     0    0     0    0    0
* Vlan5                    0     0    0     0     0    0     0    0    0
* Vlan6                    0     0    0     0     0    0     0    0    0
* Vlan9                    0     0    0     0     0    0     0    0    0
* Vlan14                   0     0    0     0     0    0     0    0    0
* Vlan15                   0     0    0     0     0    0     0    0    0
* Vlan17                   0     0    0     0     0    0     0    0    0
* Vlan19                   0     0    0     0     0    0     0    0    0
* Vlan23                   0     0    0     0     0    0     0    0    0
* Vlan50                   0     0    0     0  3000    3  3000    3    0
* Vlan99                   0     0    0     0  7000    8  2000    2    0
* Vlan100                  0    42    0     0  1000    3  3000    5    0
* Vlan101                  0     0    0     0     0    0     0    0    0
* GigabitEthernet1/0/1     0     0    0     0 287000  504 296000  519    0
* GigabitEthernet1/0/2     0     0    0     0  2000    2 70000   19    0
  GigabitEthernet1/0/3     0     0    0     0     0    0     0    0    0
* GigabitEthernet1/0/4     0     0    0  1381 502000  910 12156000  1072    0
* GigabitEthernet1/0/5     0     0    0     0 7299000  1073 954000  283    0
* GigabitEthernet1/0/6     0     0    0 1326792 13000   17 162000   47    0
* GigabitEthernet1/0/7     0     0    0     0 34000   17 127000   56    0
* GigabitEthernet1/0/8     0     0    0     0  2000    2  8000   12    0
* GigabitEthernet1/0/9     0     0    0   789 13967000  1783 14085000  1806    0
  GigabitEthernet1/0/10    0     0    0     0     0    0     0    0    0
* GigabitEthernet1/0/11    0     0    0     0  3000    3 11000   10    0
* GigabitEthernet1/0/12    0     0    0 80015248 1018000  133 137000  125    0
* GigabitEthernet2/0/1     0     0    0  5822 6337000  533 8873000  772    0
* GigabitEthernet2/0/2     0     0    0     0     0    0 59000   23    0
  GigabitEthernet2/0/3     0     0    0     0     0    0     0    0    0
* GigabitEthernet2/0/4     0     0    0  5418 28047000  2682 9021000  1639    0
* GigabitEthernet2/0/5     0     0    0   447 2481000  350 19637000  2067    0
  GigabitEthernet2/0/6     0     0    0     0     0    0     0    0    0
* GigabitEthernet2/0/7     0     0    0     0 76000   59 424000   85    0
* GigabitEthernet2/0/8     0     0    0     0     0    0     0    0    0
* GigabitEthernet2/0/9     0     0    0   491 3565000  444 1571000  290    0
* GigabitEthernet2/0/10    0     0    0 1324067 288000   68 372000   86    0
* GigabitEthernet2/0/11    0     0    0     0     0    0  7000    3    0
* GigabitEthernet2/0/12    0     0    0 1246593 4138000  399 354000  355    0
* Port-channel1            0     0    0  5822     0    0     0    0    0
* Port-channel2            0     0    0     0     0    0     0    0    0
* Port-channel4            0     0    0  6799     0    0     0    0    0
* Port-channel5            0     0    0   447     0    0     0    0    0
* Port-channel7            0     0    0     0     0    0     0    0    0
* Port-channel8            0     0    0     0     0    0     0    0    0
* Port-channel9            0     0    0  1280     0    0     0    0    0
* Port-channel11           0     0    0     0     0    0     0    0    0
FG-SW-CORE#sh platform port-asic stats nonzero-drop
Port-asic Port Drop Statistics - Summary
  Port  0 TxQueue Drop Stats: 322
  Port  1 TxQueue Drop Stats: 88811
  Port  2 TxQueue Drop Stats: 126
  Port  3 TxQueue Drop Stats: 1415610
  Supervisor TxQueue Drop Statistics
    Queue  3: 277850321
    Queue  6: 8852
    Queue  7: 120231
    Queue  8: 327898562
    Queue 10: 4285766
    Queue 11: 15
Port-asic Port Drop Statistics - Details
  RxQueue Drop Statistics
  Port 0 TxQueue Drop Statistics
    Queue 1
      Weight 0 Frames 322
  Port 1 TxQueue Drop Statistics
    Queue 1
      Weight 0 Frames 322
    Queue 3
      Weight 2 Frames 88489
  Port 2 TxQueue Drop Statistics
    Queue 1
      Weight 0 Frames 126
  Port 3 TxQueue Drop Statistics
    Queue 1
      Weight 0 Frames 1224031
    Queue 1
      Weight 1 Frames 2
    Queue 1
      Weight 2 Frames 15
    Queue 3
      Weight 2 Frames 191562
    Queue  3: 277850321
    Queue  6: 8852
    Queue  7: 120231
    Queue  8: 327898562
    Queue 10: 4285766
    Queue 11: 15
Updated image to12.2(50)SE5, problem gone!
I am seeing this issue with the output drops -
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 4292837015
The swtich is in a stack - its the second WS-C3750G-24PS and the software version is
I thought bug - CSCso81660 was fixed in this version ? Any ideas ?
James
Hi James,
Output drops might be due to real packet drops. Please check with the 'show platform port-asic stats drop gi ' command to see if drops are seen in hardware.
Please also refer to the following post:
https://supportforums.cisco.com/thread/2079859
Best regards,
Andras
