3750 portfast
JunghunLim7806
Beginner
Beginner
When I set up portfast to physical and logical ports, I want to know if it works the same way and what the differences are.
thank you.
For Portchannels, you apply the command to the Portchannel interface only and the individual physical interfaces will inherent the config from the Portchannel.
Reza Sharifi
Usually portfast applies to physical ports facing end devices like PCs, Laptops, printers, etc..
Not sure what you mean by logical? If it is on Portchannles, it works the same way and has the same effect.
thank you,
If so, do you need to configure portfast on both int port channel1 and the physical ports it contains?
Are there related Cisco documents?
