3750 rommon xmodem command unknown
neil
Community Member
I am trying to xmodem an image to flash but when I enter the command in rommon to xmodem. I receive:
switch: xmodem
Unknown cmd: xmodem
Not sure why I am getting this. It has always worked in the past.
Collin Clark
It's been a while since I had to do that, but don't you invoke XMODEM through the terminal emulator (ie SecureCRT)?
I got it
I did copy xmodem[filename] flash:[filename]
That seemed to work
Edison Ortiz
The routers using the command xmodem while the switches use the command copy xmodem..
glen.grant
I can also advise you to set the baud rate on the switch and the terminal emulator to 115200 , this will take a download of code of this size from like 2 hours down to like 15 minutes .
