Etherchannel
alyasrazzaq
Community Member
Hi, what is the lowest IOS version anyone has had etherchannel working on? I am trying to setup etherchannel between a 2950 and a 3500. The 3500 has the ios c3500xl-c3h2s-mz-120-5.3.wc.1.bin. However, i don't have the channel-group interface command and the 'interface port-channel 1' command keeps coming back with incorrect syntax, even though the port-channel option is available.
Thank you.
5 Replies 5
Thank you for that, that works perfectly. Just out of interest do you know whether the 3500 series support LACP with regards to etherchannel, or was that introduced in a much later ios?
You may use this link for any feature comparison:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
No LACP is not supported on the old 3500XL series . The last version for the 3500 series was 12.0 code.
