3750 Switch Stacks
David Grimm
I have a 3750 stack that I need to remove a switch from and reconnect the stack cables. Has anyone performed anything like this in a production environment without powering down or rebooting? I figure if anything i would have to provision the old switch out of the stack and renumber one of them.
Thanks for any help!
DuncanM2008
Level 4
Level 4
Hi David,
How many switches are in the Stack and which switch number is the switch you want to remove?
There are 7 switches in the stack. Switch #1 is master and all others are members. I want to remove switch #6 and renumber switch #7 to switch #6. I don't know if disconnecting the stack cables will affect all switches or just the two being disconnected until I reconnect them back together.
Hi David,
If you are removing switch #6 and you plan to renumber switch #7 as switch #6 you will have to reboot that switch for it to take the new number.
As long as you maintain ATLEAST a half duplex stack ring (you can verify this via "show switch stack-ring speed") the stack connectivity will not be adversely affected.
