3750 Upgrade problem
andrewdykes
Community Member
I have a 3750 (WS-3750G-24TS) that I am trying to upgrade with no success thus far.
I ftp the image to the flash, verify the image successfully, and then reboot. On boot the image loads for a while then I get the "Error loading image:..." then it loads the old image. I've tried re-uploading the image several times. This worked fine on my other 3750.
I am running advipservices 12.2(25) and I am trying to upgrade to 12.2(37) advipservices.
Any reasons why a verified image would fail to boot?
Andrew
Hieu Cao
Level 7
Level 7
Hi Andrew,
You might want to check/set the boot path for the new image. Do a "show ver", "show boot" and "sh flash" to check and verify that you've the right image on flash.
hth,
hieu
Thanks, but I have already verified the boot path, and the image actually starts to decompress. ( Loading...@@@@@@@@) I get about 6 lines of "@" and then I get the error.
