3750-X stack port question
6tgreene
We have 50 network closets all with 3750-x switches. Every now and then we receive the following error on switches that have been up and running with no issues for a long time. We have checked the stack cables they are tight and the swiches are no rebooting all switches in this stack have been up for 22 weeks thanks.
%STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 2 has changed to state DOWN
Jun 17 10:17:29: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 3 has changed to state DOWN
Jun 17 10:28:38: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 2 has changed to state UP
Jun 17 10:28:39: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 3 has changed to state UP
10 Replies 10
Rick Morris
Level 6
Level 6
Does this happen to all the switch stacks or only certain ones?
I am assuming you have changed the stacking cables?
InayathUlla Sharieff
Try changing the Stack Cables.
Whats the firmware version running on the switch?
6tgreene
I have changed the stack cables, and it does not happen to all the switches in the stack. The log I posted is from a 6 swtich stack.
I also have 2 switch stacks that it happens to also.
6tgreene
I have one stack with the following output.
Switch Ports Model              SW Version            SW Image
*    1 54    WS-C3750X-48P      15.0(1)SE3            C3750E-UNIVERSALK9-M
     2 54    WS-C3750X-48P      15.0(1)SE3            C3750E-UNIVERSALK9-M
     3 54    WS-C3750X-48P      15.0(1)SE3            C3750E-UNIVERSALK9-M
     4 54    WS-C3750X-48P      15.0(1)SE3            C3750E-UNIVERSALK9-M
     5 54    WS-C3750X-48P      15.0(1)SE3            C3750E-UNIVERSALK9-M
     6 54    WS-C3750X-48P      15.0(1)SE3            C3750E-UNIVERSALK9-M
I also have a 2 switch stack with the same issue
*    1   52     WS-C3750-48TS      12.2(25)SEA             C3750-I9K91-M
     2   52     WS-C3750-48P       12.2(25)SEA             C3750-I9K91-M
During the stacking dropping and adding is there any impact to the users?
I have seen a lot of weird issues with the 3750X IOS that has a lot of bugs but nothing service impacting.  For instance, almost from day 1 there is a CPU issue that shows the HULC LED process at 20%, and the total cpu processor around 40% utilization.  This is a known bug in the code that they have not fixed in at least 3 versions that I know of.
I am not suggesting it is a bug but I would not be suprised to find out that it is not service impacting and mearly a cosmetic issue (bug) in the code.
Correct, there is no service impact to users on the stack.
I am sure you already saw this page, but if not here is a good link that discusses the stackwise issues you have shown here.
http://www.cisco.com/en/US/customer/docs/switches/lan/catalyst3750/software/troubleshooting/switch_stacks.html#wp39183
There are some good steps to try as well as some good commands for verification.
I Could see there are two images installed on two different stack and sorry to say that they are not pretty good IOS.
Hence action plan straight away would be to upgrade/downgrade the firmware to12.2(55)SE7 to avoid and get many problem resolved.
Inayath
6tgreene
Yes, I have seen that link you sent. I have tried all the suggerstions on the page
Well, I am all tapped out.  The last thing I found was this link
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsj80738
Sounds like the logging notification is the same but maybe not the same scenario you are experiencing.
