qos configuration failed on SVI interface
Rojer-bkk
Hi All,
I'm wondering why i cannot apply qos service-poly into SVI interface if using IOS 12.4T. However, I can apply if i use 12.4 release. I check configuration guide as well as command reference on each version but cannot find this information. Could somebody please share information about this?
12.4T  (c2800nm-advipservicesk9-mz.124-15.T10)
12.4    (c2800nm-advipservicesk9-mz.124-16a)
router2811(config-if)#service-policy output app_internal
Configuration failed!
I configure simple MQC as below
class-map match-all class-Test
match access-group name acl-Test-app
class-map match-all class-Production
match access-group name acl-Production
match not access-group name acl-Test-app
match not access-group name acl-File
policy-map app_internal
class class-Voip
  bandwidth percent 10
class class-Test
class class-File
class class-Production
  bandwidth percent 35
InayathUlla Sharieff
Rojer,
As per the configuration guide it is supported.
Only issue is:-
  • Service-policy on Point-to-Point Protocol over X.25 (PPPoX) interfaces is not supported.
Inayath
Hi Inayath,
I got error configuration failed after i try to apply to SVI
Look like limitation of Qos on ISR router. It's not software issue.
The HWIC in the router supports limited QoS features. If you see the config failed on the later IOS release that is because the parser was updated to reject the config. Older IOS releases would allow it even if it isn't supported. Here is a whitepaper detailing what QoS features you can use.
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/prod_white_paper0900aecd8064c9f4_ps5855_Products_White_Paper.html
HTH,
Dale
