3845 failure..
xtam1
Level 3
Level 3
Dear All,
i have a problem where suddenly the router failed and when i connected to its console port i logged the attached output. Also below is the last show version taken before the failure (1 week ago).
I need help to resolve this problem,
Thanks..
------------------ show version ------------------
Cisco IOS Software, 3800 Software (C3845-IPVOICEK9-M), Version 12.4(9)T1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 30-Aug-06 19:46 by prod_rel_team
ROM: System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
New_Xbox_IR uptime is 15 minutes
System returned to ROM by bus error at PC 0x605A80F4, address 0x702B82E8 at 10:19:56 UTC Wed Oct 11 2006
System image file is "flash:c3845-ipvoicek9-mz.124-9.T1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3845 (revision 1.0) with 1005568K/43008K bytes of memory.
Processor board ID FTX1023A1PT
2 Gigabit Ethernet interfaces
252 Serial interfaces
10 Channelized E1/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
250880K bytes of ATA System CompactFlash (Read/Write)
balajitvk
Level 8
Level 8
Hi Tam,
From the Show version o/p,
This router was last restarted by a bus error:
'bus error at PC 0x605A80F4, address 0x702B82E8 at 10:19:56 UTC Wed Oct 11 2006'
The system encounters a bus error when the processor tries to access a memory location
that either does not exist (a software error) or does not respond properly (a hardware
problem).
TRY THIS: Issue a 'show region' and check if the address location (the 'address'
part of the bus error) falls within an existing address range. If the address reported
by the bus error does not fall within the ranges displayed in the 'show region'
output, this means that the router was trying to access an invalid address. This
indicates that it is a Cisco IOS Software problem. Paste the output from the 'show
stacks' command to decode the output and identify the Cisco IOS Software bug that
is causing the bus error. If the address falls within one of the ranges in the
'show region' output, it means that the router was accessing a valid memory address,
but the hardware corresponding to that address is not responding properly. This
indicates a hardware problem. Try reseating the hardware belonging to this address
range before attempting to replace it.
Rate if it does,
Rgs
thanks for the reply, and yes it was rebooted due to a bus error but that was one week ago and it came back to normal with no problems until today show the following errors:
virtual address corresponds to main:text, cache word 0
Cache Data not Available for CPU 401
Error searching L1 for cache address: 0x623BF300
Cache error detected!
CPO_ECC (reg 26/0): 0x20000000
CPO_CACHERI (reg 27/0): 0x04001300
CPO_CACHERD (reg 27/1): 0x00000000
CPO_CCHEDPA (reg 27/3): 0x10A20000
Real cache error detected. System will be halted.
0 spurious cache errors were previously detected.
Error: primary instr cache, fields: , SysAD
virtual addr 0x623BF300, physical addr(21:3) 0x001300, vAddr(14:12) 0x0000
Low Data High Data Par Low Data High Data Par
DRAM Data: 0:0x00000000 0x00000000 0x00 1:0x00000000 0x00000000 0x00
2:0x00000000 0x00000000 0x00
3:0x00000000 0x00000000 0x00
pkp000001
Community Member
I was able to resolve this issue by  replacing DRAM sticks.
