Showing results forĀ
Search instead forĀ
Did you mean:Ā
3850-24P with 2 x 10GE Network Module and 4x sfp..
Peter Handke
I have switch WS-C3850-24P-S with module C3850-NM-2-10G and a 4x SFP-10G-LRM.
Can I use this sfp+ module in Gi1/1/1 and Gi1/1/2 as 1 Gb/s port ? Or can i use this sfp as 1Gb/s ? I need to have 4 fiber ports, no matter  10Gb or 1 Gb/s, just 4 optic ports.
Now, i have in log:
%PM-4-ERR_DISABLE: gbic-invalid error detected on Gi1/1/2, putting Gi1/1/2 in err-disable state
Thanks for any help or advice
greetings
Peter
Marvin Rhoads
The C3850-NM-2-10G module supports 10 Gbps SFPs only in the two rightmost ports. If you need four active SFPs in that module, they must all be 1 Gbps SFPs. The hardware installation guide explains the supported combinations here.
Compatible 1 Gbps transceiver types for the 3850 are listed here.
You cannot run a 10 Gbps transceiver (such as your SFP-10G-LRM) at 1 Gbps.
Hope this helps. Please rate helpful posts.
15 Replies 15
Marvin Rhoads
I thought that 10 Gb/s can work with 1 Gb/s speed, in Gi1/1/1 or 2 slot. Now i have to buy extra sfp just for 1 Gb/s
Thanks for explanation.
You're welcome.
Generally speaking almost all optical transceivers are limited to their rated speed (and only that speed) due to how the optical component (LED or laser) is manufactured. There are a few exceptions but they are not very common.
It's not as simple as with a 10/100/1000 copper Ethernet NIC where the multi-speed support is built into the ASIC.
Thanks for the rating.
i have similar situation
i have a 3850 with C3850-NM-4-1G
i am running ios XE 3.7
i installed GLC-SX-MMD and i get the same error
the module is only for 1gb
is it a bug? i can't find anything that says about a bug
update
i used the non Dom gbic and worked
there must be a bug
GLC-SX-MM worked
Hello experts,
We are having WS-C3850-12S-S and WS-C3850-24T-S in stack.
and am facing this same issue with my 12S-S switch i have upgraded the ios from 03.07.03E to 16.1.2 but still the problem persists ..am confused what to do now.
we are using GLC-SX-MMD= SFP modules ..what should be done in this case..
a final solution.
You may also want to take a look at this link as a reference.
3850: Understanding interface configuration on NM modules
https://supportforums.cisco.com/docs/DOC-36084
Lp
Hi Marvin, I have a similar issue...
I have a a C3850-24P-S with a C3850-NM-2-10G, however i am using a GLC-SX-MMD.
When i insert the transceiver i get this message:
%PLATFORM_PM-6-MODULE_ERRDISABLE: The inserted SFP module with interface name
Switch#able state
Is this transceiver support on these modules?
Am i doing something wrong?
Thanks!
The GLC-SX-MMD is supported n the C3850-NM-2-10G module as long as you don't already have 10 Gbps transceivers in the rightmost ports.
Can you share the output of:
     show int status | b Gi1/1/1
...so we can see a bit more detail?
Hi Marvin, I have exactly the same problem with a C3850-NM-2-10G and GLC-SX-MMD. I've tried the GLC in two different stacks with different NM but I've received the same error. Both 3850 stacks running IOS XE 3.2.3
Do you have any ideas?
Thanks!
Francesco
Marvin my apologies for the delay.
Here are the results from the requested command:
Switch>show int status | b Gi1/1/1
Gi1/1/1                      err-disabled 1            auto   auto unknown
Gi1/1/2                      err-disabled 1            auto   auto unknown
Te1/1/3                      err-disabled 1            auto   auto unknown
Te1/1/4                      notconnect   1            auto   auto unknown
Switch>
When i originally inserted the transceiver i got this message:
with interface name Gi1/1/1 is not supported
%PM-4-ERR_DISABLE: gbic-invalid error detected on Gi1/1/1,
putting Gi1/1/1 in err-disable state
Please advise, thanks.
You should be able to do 2 X 1Gb and 1 X 10Gb in that module. Have you tried removing the 10Gb optic since it's not connected anyway? Maybe in the 2/1 configuration, the 10Gb needs to be in te1/1/3?
I believe this is an IOS bug.  Have you guys tried using OLD GLC-SX-MM (non-DOM)?
Hi Leo, I've tried with GLC-SX-MM and it works correctly!
