3850 clear flash: space
ctc.ciscotech
I have a new Catalyst 3850 24T. I want to upgrade it to the latest IOS XE. I have uploaded the bin file, but it says it doesn't have enough space to extract it. I am new to XE, and I'm unfamiliar with all the things in flash: Does anyone know what is safe to delete to clear up some space for me? cat3k_caa-universalk9.16.03.07.SPA.bin is the one I'm trying to boot from.
Switch#dir flash:
Directory of flash:/
8094 -rwx 2097152 Jan 5 2019 00:41:30 +00:00 nvram_config
8083 -rw- 537489817 Jan 5 2019 00:31:33 +00:00 cat3k_caa-universalk9.16.03.07.SPA.bin
8086 -rwx 30418104 Sep 25 2014 07:53:39 +00:00 cat3k_caa-iosd-universalk9.SPA.150-1.EX3.pkg
8088 -rwx 64586444 Sep 25 2014 07:53:39 +00:00 cat3k_caa-wcm.SPA.10.0.120.0.pkg
8096 -rw- 1237 Mar 11 2017 18:55:03 +00:00 packages.conf
8092 -rw- 1248 Apr 3 2015 11:08:35 +00:00 packages.conf.00-
40406 -rw- 34846028 Apr 3 2015 11:08:31 +00:00 cat3k_caa-iosd-universalk9.SPA.150-1.EZ5.pkg
40408 -rw- 77456192 Apr 3 2015 11:08:31 +00:00 cat3k_caa-wcm.SPA.10.1.150.0.pkg
8090 -rw- 303772864 Mar 11 2017 18:49:07 +00:00 cat3k_caa-universalk9.SPA.03.06.06.E.152-2.E6.bin
8082 -rwx 1224 Sep 25 2014 07:53:49 +00:00 packages.conf.01-
8097 -rw- 83293932 Mar 11 2017 18:54:58 +00:00 cat3k_caa-base.SPA.03.06.06E.pkg
8098 -rw- 3982012 Mar 11 2017 18:54:58 +00:00 cat3k_caa-drivers.SPA.03.06.06E.pkg
8099 -rw- 33788908 Mar 11 2017 18:54:58 +00:00 cat3k_caa-infra.SPA.03.06.06E.pkg
8100 -rw- 43074880 Mar 11 2017 18:54:58 +00:00 cat3k_caa-iosd-universalk9.SPA.152-2.E6.pkg
8101 -rw- 28394380 Mar 11 2017 18:54:58 +00:00 cat3k_caa-platform.SPA.03.06.06E.pkg
8102 -rw- 111233856 Mar 11 2017 18:54:59 +00:00 cat3k_caa-wcm.SPA.10.2.160.0.pkg
8095 drwx 4096 Nov 9 2018 14:12:14 +00:00 dc_profile_dir
1562509312 bytes total (204087296 bytes free)
Thanks!
17 Replies 17
dir flash:
69842 -rw- 2097152 Oct 28 2024 12:18:14 +00:00 nvram_config
69843 -rw- 82665136 Apr 17 2016 01:13:19 +00:00 cat3k_caa-base.SPA.03.06.04.E.pkg
69844 -rw- 4913852 Apr 17 2016 01:13:19 +00:00 cat3k_caa-drivers.SPA.03.06.04.E.pkg
69845 -rw- 33784816 Apr 17 2016 01:13:19 +00:00 cat3k_caa-infra.SPA.03.06.04.E.pkg
69846 -rw- 43021636 Apr 17 2016 01:13:19 +00:00 cat3k_caa-iosd-universalk9.SPA.152-2.E4.pkg
69847 -rw- 27417488 Apr 17 2016 01:13:19 +00:00 cat3k_caa-platform.SPA.03.06.04.E.pkg
69848 -rw- 111180608 Apr 17 2016 01:13:19 +00:00 cat3k_caa-wcm.SPA.10.2.140.0.pkg
69849 -rw- 1244 Apr 17 2016 01:13:28 +00:00 packages.conf
69850 drwx 4096 Oct 28 2024 12:17:33 +00:00 dc_profile_dir
69852 -rw- 19596 Aug 5 2022 20:09:24 +00:00 vlan.dat
69853 -rw- 0 Oct 25 2024 13:26:10 +00:00 yes
69854 -rw- 0 Oct 25 2024 13:25:49 +00:00 system
69855 -rw- 0 Oct 25 2024 13:28:23 +00:00 switch
69856 -rw- 480018036 Oct 30 2024 09:39:36 +00:00 cat3k_caa-universalk9.16.12.05b.SPA.bin
69857 -rw- 0 Oct 28 2024 11:39:53 +00:00 cat3k_caa-universalk9.16.12.12.SPA.bin
1624104960 bytes total (835149824 bytes free)
omurwahabakuk
getting the same error even after copying to flash
what is the error you getting, what version you trying to install ? i see 2 files one with 0 bytes, can you post comlplete output when you upgrading to look what is wrong
bit odd orginally you installing 16.9.X now you are 2 different version.
check the release notes and upgade process for the install mode :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-12/release_notes/ol-16-12-3850.html#task_k3s_tgq_k3b
BB
